Question about Bang and Olufsen Beosound 4000 Shelf System
Cannot get colour picture
RF output from sattelite box into Bang and Olufsen MX4000 TV aerial socket gives super picture but not colour
  • 122 Answers
Check tv colour system is correct for your region, this is shown in the tuning menu, adjust if required
Posted on Jan 11, 2010
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Cannot get techwood tuned in to sky through rf do not have a manual
Sorry to say modern TVs do not have an analogue tuning system, which you need for a SKY box RF output. Your local TV dealer may have an RF receiver that you can connect to a SCART or RCA socket on your TV
Feb 06, 2018 | Televison & Video
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
I was given a GE 27GT616 television but can't figure out how to connect a converter box or dvd player
If your tv has video in socket (yellow color)and audio in socket(white color),you will connect the dvd player audio video output. it will give give clarity picture. your tv have not av socketyou can connect your dvd player audio video output to converter audio video input.And then connect to converter RFout to tv Rf input(antenna socket)and tune the tv you wlii get picture.
Jul 31, 2010 | GE 27GT616 27" TV
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
How do I connect my sky eye? It arrived with no instructions and I am not sure what i need to do! I have a sky box in one room and now the sky eye connected to my tv in the other room - does it plug onto...
You need an aerial connection between the two units,the aerial will plug into the eye and then the eye into the tv.The cable connects into your sky box in the one marked output 2.You then need to go into service`s on the sky box,select 4,then press 0 1 select,goto rf output and turn on.
Nov 11, 2009 | Televison & Video
Setup VCR to TV, using RF plugs & coaxial cable
The solution was both simple and elementary - why didn't I remember it sooner?
The TV needed to be 'tuned' to the video just as it needed to be tuned for each TV channel.
I selected channel 12 on the TV, went into the tuning mode on the TV and with the video playing, cycled through the TV tuning process until, Voila, there was the video showing on the TV.
Oct 14, 2009 | Philips Televison & Video
138 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
