Question about Garden
I own a Snapper Lawnmower, model number sr 1030. it really is hard to start...doesn't want to turn over. I changed the spark plug. Can I check the starter myself??
    Sergeant:
  • 353 Answers
Check the oil for the presents of fuel
may be full of gas due to stuck bowl float
Posted on Jun 20, 2009
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
Starter on snapper re110 not always working
does it crank no start/hard to restart
or
no crank
BIG difference
Oct 20, 2014 | Snapper RE110 28 inch 11.5 HP Rear Engine...
725 ex briggs and stratton
Might be the carburetor or air filter dirty. Need right amount of air to mix with fuel at the right time.
To service these best to check this video out. Yours may not be the same exact model but gives an idea.
REPAIR BRIGGS STRATTON LAWNMOWER TUNE UP CARBURETOR CLEAN
Sep 01, 2014 | Snapper Garden
Why does the mower deck on my Snapper SR 1030 constantly fall and scalp my grass?
Some part(s) are worn out or broken in the height adjustment section. If it has a handle with a button for that adjustment, check it from top to bottom, and the linkage it connects to at the bottom of the handle. www.mowpart.com will have a parts breakdown.
May 27, 2014 | Snapper Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
No spark on W1-185V
I seem to go through this every year my lawnmower. What I do is drain the fuel tank and fill with fresh fuel. Then I replace the spark plug with a new one and it starts up right away. Otherwise I'd take it to a small engine repair shop for a tune up.
May 20, 2012 | Snapper Garden
My snapper hi-vac niwer us hard to start. I can't pull hard enough to get it to start. It uses straight gas, not mixed with oil.
If you are having problems starting your mower you shouldcheck 3 things, air, fuel and spark.
Fuel: check to make sure you are full of good quality fuel, try to start theengine several times then take out the spark plug and it should look wet. If its not wet then you aren't getting fuel into the engine.
Air: remove and clean the air filter with clean gasoline if its made offoam. If its made of paper then you should buy a new one from a localauto parts or hardware store.
Spark: disconnect the spark plug wire from the spark plug and hold thewire close to the engine block. Try to start the engine and watch for aspark to jump between the end of the wire and the engine block. If itdoesn't then either the wire is bad or the ignition coil is bad.
Jun 09, 2011 | Snapper 217020b Lawn Mower Mowers...
Engine will not start. Use to start really good. Changed spark plug.
Take out the spark plug put it to the head and pull the engine over and check if there is any spark if there is it's a fuel problem and not well check the coil. Now if there is a spark put a wee drop of fuel into the plug hole put plug in and pull over if it fires then you know it's a fuel problem it's ethier the carb or bad pettrol.L davidson lawnmower tech
Feb 06, 2011 | Garden
Snapper lawnmower will not start - sparkplug is good, air filter clean, no idea what is wrong
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the vertical intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jul 05, 2010 | Omega Rear Drive Wheel Snapper Mowers
Snapper rear engine lawnmower jerking and injuring.
the clutch on the engine probably needs replacing
Oct 19, 2009 | Garden
Garden Logo
603 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
