Question about Carrier 52CQ315 Air Conditioner
How to wire new motor & capacitor
HEEELLLLPPP!! I want to replace the motor and capacitor on my carrier model 38tho60300, but the new capacitor has only 2 terminals (old one has 3)and the motor shaft is 4 times as long. How do I do the wiring? Is there a schematic for the average "joe"?
  • 8,220 Answers
Do not panic. The new motor has several ways to connect common. READ MORE
If this is a fan for inside then you have the speeds to contend with. The info on the READ MORE link is for that of a central unit but it covers your question too. As far as the shaft being too long you have to cut that yourself. I have an electric hacksaw that cost $500 bucks from milwaukee tools that does a fair job of that.
Posted on May 16, 2009
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
My Carrier rooftop ac blower motor quits blowing. It'll run fine for a while, maybe up to 8 hours or so and then just quit. If I go up to the roof and spin the fan motor and then come back down an
There is probably only 1 wire leading to the F or FAN terminal on the capacitor. You remove the 1 wire to the fan side of the capacitor and connect it to the new fan capacitor. Then you take an extra wire that you will need to make, buy, or find, and connect it from the opposite terminal on your new capacitor. Meaning the other side that of the capacitor. Then connect that new wire from the new capacitor back to the old capacitors C or COM terminal. Clear as mud I know, but basically you run your fan capacitor wire to the new capacitor, then the other side of the capacitor runs back to common on the old capacitor. And beware! Those things can hold a charge!!! Disconnect all power & discharge the capacitor! Hope this helps
Mar 02, 2017 | Heating & Cooling
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Compressor shuts down after 30 minute run time resets in 1hr Motor windings open after shutdown Capacitor OK pressure 70 low side, 240 liquid side Load AMP 18/18
Check and tighten all wiring. Replace the capacitor and add a HardStart to the capacitor.Check the indoor coil for dirt/dust/obstruction. Check the outdoor fan motor for over-heating.
Sep 11, 2011 | Carrier 38CKC036 Air Conditioner
Wire an AC fan motor
Look at the schematic on the new motor , but i think if the 2 purple wires go each one to each side of the capacitor, the black to line and you need to connect the other line which Im 99% sure is the whte wire which is the only one left.Remember you need 220v between the fan motor lines for it to work.
Sep 30, 2009 | Carrier 38CKC036 Air Conditioner
Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
sounds like a bad capacitor usually screwed to the blower housing (round or oval shiny can)
this gives the motor a kick start)
depending on the motor there is usally two brown wires that go to it
check the mfd rating on it probably 5mfd and replace it with a matching one
its a very inexpensive part
Aug 02, 2009 | Carrier 38CKC036 Air Conditioner
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 52CQ315 Air Conditioner Logo
118 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
