Question about Sangean ATS 808A AM/FM/SW Radio
Old Shortwave Tabletop Radio
It s made by a company called Lafeyatte Electronics, it has 11m,19m,29m it has six meter bands to it. I tried using a long wire Antenna but it overloads. And I can't seem to turn it down. Is there a way to make a homemade Antenna for it . I live in an apartment where I use it at my bedroom window. Keep it or Trash it?
  • 17 Answers
The antenna may be too long. Try using a shorter antenna.
Posted on Aug 04, 2009
    Problem Solver:
  • 9 Answers
HELLO,
TO SOLVE YOUR PROBLEM YOU NEED
TO GET A SW ANTENNA TUNER.
THE ONE I BOUGHT IS
MFJ-956 TUNER
THIS WILL PREVENT THE WIRE THAT IS
NOT TUNED TO BE TUNED TO THE RIGHT
BAND 11M TO 160M
RONS ELECTRONIC
Posted on Feb 07, 2009
Manual for grundig 750 radio
Here is a link to the manual for your radio.
http://www.etoncorp.com/sites/default/files/GS750_Manual.pdf
Dec 11, 2014 | Grundig Eton Satellite 750...
I need help figuring out exactly how old the CB radio, if it even is one in my possession, actually is? It is a "Cobra 17" Solid State Citizens Band 2-way Radio. Made by a corporation called...
Dynascan was around in the 70's and early 80's. I would take a look at the manual it should have a publication copyright year on it, or look at the serial number plate on the back of the radio some times the year the radio was made is on it. This would be the only clue to the age of the radio.
Jul 20, 2011 | Radio Communications
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
Cannot select USB or SSB.Displays LSB or LISB? Very poor reception
On the Satellit 750 you have a button marked SSB. If you have selected a shortwave band then you can press the SSB button. Pressing the button repeatedly will toggle between LSB and USB.
You will need to know the exact frequency and the broadcast time, and the side band. Turn the radio on. Select a frequency which you know carries SSB signal and wait. Those that broadcast on SSB are not radio stations, maybe ham radio operators.
You can also select a short wave band, press the SSB button once or twice to select the side band and launch the automatic tuning system. It will scan the meter band and stop for a few second when it receives a strong enough signal. If you are able to perceive a clear signal on LSB or USB then you found a broadcaster. Some radios just have SSB and you cannot choose the side.
Personally, when I buy a radio I always insist on SSB but I have never been lucky tuning in an SSB signal. I keep trying once in while.
Jun 23, 2011 | Grundig Satellit 800 AM/FM/SW Radio
I just purchased the G6 Aviator. The FM band works well, but none of the AM or shortwave stations get reception. I have tried the antenna up and down, indoors and outdoors with no success.
It sounds like the whole am band is not working which includes the shortwave bands, there is no remedy to correct this and is clearly a manufacture defect. The best solution is return the radio because there is nothing more that can be done in it's present condition.
Mar 03, 2011 | Grundig G6 Aviator (Buzz Aldrin Edition)...
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
No am on am band
Usually the "front end" of the radio has a bad FET transistor. This is caused by a static zap at the antenna. Early models suffered from this and the cure is to replace the FET and add protection diodes. If you need help with this email me at.... poikaa@yahoo.com
Rod
Nov 08, 2009 | Sony ICF-2010 AM/FM/SW Radio
Shortwave programmes
Before you call a doctor or an exorcist, verify that you're using your shortwave receiver under normal condition. There are several factors which affects reception of whortwave programs and signals.
1. Check for the time and frequencies. Depending on your country and location, all Shortwave time zones are based on World Time in UTC or GMT ("Universal Time Coordinates" or Greenwich Mean Time") In my country (Philippines, Asia) for example, we are 8 hours advanced from World Time. You can check your time zones and regions using a world map.
2. Check for propagation and band conditions/ openings. During daytime higher frequencies such as 9 -21 Mhz are active, while nightime frequencies are the lower bands such as 3 - 9 Mhz. Daytime and nigthime divider frequency is about 10 Mhz, that means you might receive signals under most conditions during daytime and night time. Check some technical books on amateur radio operations or magazines for radio reception. It might be worthwile to study books or materials on receiving international broadcasts stations before you can receive good or adequate shortwave signals. This might become your hobby too, "DXing" or receiving distant stations from across the world. Try it, but it might be an addicting hobby once you're drawn to it!
3. Check if any shortwave station broadcast in any specific time of day at any frequency. Shortwave broadcasts are scheduled based on band openings mentioned above. If for example I'm a Shortwave broadcaster from Asia, and would like to broadcast my signal through the Americas, I would use band openings with respect with time zones. If it is night time in the Philippines, and daytime in the Canada, I would use the higher frequencies to propagate my signal. So I would specify the time for example "8:00 pm Philippine local time, 12 hours UTC, and 7 am in Canada"--- Asia: 8 hours advanced to UTC, Canada--- 5 hours behind to UTC). So shortwave broadcast schedules varies. Broadcast schedules are available on the net, just search for the Shortwave station you want to hear such as Radio, Japan, Radio Australia, BBC, DW (Deutche Welle) Radio in Germany, China Radio International... There's too many shortwave stations waiting to be discovered out there! Check some books and magazines too such as Popular Communications, Monitoring Times, Passport to World Band Radios, World Radio and TV Handbook, etc. You may want to check if any station would be broadcasting in your dialects as most of these mainstream and regular broadcasters are multilingual.
2. Check your location. If you are using your radio indoors, shortwave signals might not entering your homes or offices due concrete walls and metal railings or fence. There are many factors which blocks radio waves especially in the HF or lowetr bands. Try receiving AM (Mediumwave) first. If it cannot receive any AM station, then you would not receive any Shortwave signal at all, even if you extend fully the telescopic whip. If you cannot receive AM or Shortwave signal indoors, try using your receiver outdoors.
2. Check for local interference. Your receiver might be receiving interference from noise generating gadgets such as PC monitors, TV sets, faulty wall adapters or switching power supplies, motor operated appliances such as washing machines or vacuum cleaners, flourescent lamps, etc. Try turning off or unplugging each of these mentioned gadgets to see if they are the cause. Faulty house wiring or powerline noise might also cause some interference noise which could drown shortwave signals, verify this with your local electrical technicians.
3. Check your radio's settings. Depending on the radio that you use, there might be settings such as attenuator or RF gain, be sure that attenuator are set to zero or turned to off, and RF gain to high. Attenuator must be turned to minimum or OFF position, unless you are receiving too much signas from nearby radio stations. Setting attenuator to mid or high position will attenuate most weak signal, and only those strong local stations will pass through. Setting too much attenuation will prevent you from receiving any station at all. Same with RF Gain, always set it to highest gain setting unless you are receiving too much signals which might overloads your shortwave radio.
4. If these troubleshooting efforts above doesn't works and you still cannot receive any station, then your radio's front end parts might had burn out due to signal overloads. Burn parts might include one or several transistors or diodes. Let your local service technicians check your radio and solve the problem for you. If your radio is still under warranty, send it back to the store or dealer, and let a qualified technician do the repair.
MANNY DE GUZMAN JR.
SoundMagik Home Studio
Site Creator, Teen Models 2007
Visit my website at http://mannydeguzmanartist.wetpaint.com/
My YouTube Channel, http://www.youtube.com/user/mannydeguzmanjartist
My imeem social media channel, http://mannydeguzmanartist.imeem.com/
My Talents and Modeling site at http://teenmodels2007.wetpaint.com/
I've also signed up an account at Total Popstar, uploading some promotional videos. You can watch and rate my videos (you can find my videos on the right side of the screen), just click the link here: http://www.totalpopstar.com/?profile/index/&1740
Thank you very much. I hope I'll really be of help here at FIXYA.COM!!!
Jan 26, 2008 | Sony ICF-SW30 Radio
Sangean ATS 808A AM/FM/SW Radio Logo
289 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
