Question about Coleman Air Tools & Compressors
Change from 220v to 110v on air compressor
Have a magnetek century ac motor on my air compressor. can this be changed from 220v to 110v? coleman powermate blackmax 5hp. p# - 10-182533-21, hp - spl, hz - 60, ph - 1, rpm - 3450
  • trefle13c May 26, 2009
    thank you.
  • 585 Answers
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
Posted on May 18, 2009
Can I rewire my 220 compressor to 110 ?
The short answer is: No. The longer answer is, the motor and controls were designed to run on 220 Volts, and as such cannot simply be re-wired for 110 Volts. You basically have 3 options: 1) Have a licensed electrician wire in a 220V circuit to your shop/garage/shed for the compressor. 2) Change out the motor for one designed for 110V (finding one that will work could be difficult, and might require modification of mounts, spindles, gears etc and probably not worth the trouble...but technically possible) 3)purchase a step UP transformer which can turn 110V North American household current into 220V.
Sep 13, 2014 | Air Tools & Compressors
Need wiring diagram for switching volts on a century magnetek 5hp air compressor
What is the model number? Most of the Century 5 HP motors are 220 Volt single phase. What did you want to change it to?
Aug 15, 2014 | Air Tools & Compressors
How to change Emglo air compressor from 220v to 110v. Compressor is running at half speed when plugged into standard wall outlet. I bought the compressor new in the early "90's" and since then...
Hi Pete,
On the side of the motor on the label should be a wiring diagram. The diagram will tell you how to wire fro high 220v and low 110v ...
If the nameplate is single voltage only then the motor cannot be rewired for the lower voltage...
Also check the motor RPM nameplate as compared to the others...you may have a 1725 motor and the newer ones a 3450 motor...that would give them double the RPM's if the gearing or pulley sizes are the same...so.. if you have the right voltage and the RPM's of the motor are the lower, then you possibly could change the pulley sizes to speed up the compressor...
Lots to check and think about...
heatman101
Mar 11, 2011 | Dewalt Air Tools & Compressors
Electric Motor running slow
Century / Magnetek motors are used on many compressors but usually is an upgrade to have the option to easily switch from 110 to 220. Dewalt, Rol Air, Jenny, Emglo and others are considered high end compressors and come with switch for selecting voltage. One still must change the cord if selecting 220v setting. One thing in common is that 115v motors are never more than 2-3 HP because the amp draw for anything over 2hp is likely higher than 20 amps and would trip most common outlet breakers. You noted that your motor sticker lists 6.5 hp at 15 amp 220v so it could not work with 110v because it would draw over 30 amps and just not be practical. Magnetek motors are very good quality and most always state on sticker 110/220v and show wiring diagram for proper connection. Your compressor was most likely built to be stationary and be hardwired into an outlet/switchbox with heavy duty wiring or special cord to run such a high hp motor. You made a great buy however, because the motor alone lists for several hundered dollars alone. You could replace the motor with a 110v but you would loose the fast performance / recovery of that 6.5 hp motor. Like replacing a v8 engine with a 4 cyl. but expect to pull same load, not likely. Good luck with your purchase, and post again if you have other question.
Jul 11, 2010 | Coleman Air Tools & Compressors
How do i change my century 2hp electric motor on my air compressor from 220 volt to 110 volt
ASSUMING U HAVE 4 WIRES; 2-110V, 1-GROUND, 1-NEUTRAL. REMOVE AND OR DISCONNECT 1 OF THE 110V WIRES. IT STILL MAY NOT WORK PROPERLY BECAUSE U NOW JUST HALVED ALL THE VALUES; AMPS, OHMS, ETC.....CONSULT AN ELECTRICIAN 1ST.
Dec 13, 2009 | Air Tools & Compressors
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Apr 02, 2009 | Coleman Powermate 60 Gallon Air Compressor
Motor will not turn over all the time.
is it new or used, does it have oil??hydraulic lock up??compressor dump valve bad,dirty
Jan 14, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Coleman air compressor
Should be an electrical diagram on the motor. The motor name plate should also indicate if it is a dual voltage motor. There should be a cover on the end of the motor to access the terminals.
Aug 30, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
1,957 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
