Question about Husqvarna Garden
I've replaced HUCTH160D drive V-belt with correct part 165632 110" original part. Mower works but I get belt burning smell after a few minutes. When I check underneath the guide first back from the front on the right side has come off its guide. I'm wondering if there is a part missing as that guide is different from the others and just seems to be a wheel with rough surface not a proper plastic guide wheel like the rest. Has something fallen off the mower perhaps? Also I need a new steering rod and ball joint and I can't find CTH160 in the partstree.com site - is it because I'm in the UK?
  • bombaycat Jun 07, 2009
    Fixed it myself, required new pulley assembly which I've ordered and will fit.
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
lester482529
  • 226 Answers
SOURCE: Part required for Craftsman Ride on Mower 38" model 917.259040
go to parts tree.com.put in your model#.they will probably have what you need.hope this helps
Posted on Jun 17, 2009
  • 376 Answers
SOURCE: My Sears 917.272911 Lawn Tractor is eating mower drive belts
There's a couple of things that could be causing this. First, make sure the idler pulleys and blade pulleys spin freely. Second make sure the belt is behind the belt keepers on the two idler pulleys. There is only one on the left idler, but TWO on the right idler. I suspect that is your problem. Anyway, once the belt is on, engage the blades, with engine OFF, and inspect the belt routing, making sure it's not over or under something it shouldn't be.
Posted on Jul 02, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
Dolfoff
  • 148 Answers
SOURCE: Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Posted on Sep 26, 2009
Testimonial: "I removed the mower & checked everything - pulleys, bearings, mandrells, springs. All OK. Re-assembled and it works again. Thanks for your feedback."
Why burning belt on 48" Craftsman riding mower
Since you mentioned "48-inch riding mower" let's assume your question is about the mower deck and not the overall mower or its main drive belt (if manual shift-on-the-fly model). If the belt burns that means it is running but slipping against something; or that the drive sheave us turning against an impeded belt. In the first case the belt will be burned along its length; in the second the burning will be occuring in one location(s) along the belt. In any case of belt slippage, check first that all tensioners (springs) are properly in place and not broken or fatigued and in need of replacement. The only other thing would be resistance to belt running, such as:
blade blockage; blade rotor resistance from lack of grease or ruined bearing in need of replacment; grass clogging on deck underside or under blade drive pulley on deck top side; a pully sheave out of round; an obstacle between belt and sheave that is preventing free turn of sheave and belt run; misrouted belt; an overstretched belt that cannot be sufficiently tensioned. Inspect and correct or replace as needed.
Aug 19, 2014 | Craftsman Garden
Burnt rubber smell when vacuuming
This could be a few things:
A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
Hope this helps, if you need to talk further feel free to contact me.
Tim
TheVacCenter.com
Mar 13, 2013 | Simplicity Vacuums
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
Smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
May 12, 2012 | Craftsman Garden
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
MY DRYER VIBRATES VERY BADLY, THE CLOTHES STILL SPIN BUT THE WHOLE UNIT MOVES ALOT AND AFTER A FEW MINUTS IT STARTS TO SMELL LIKE SOMETHING IS BURNING.
This sounds like the rubbing strips at the front of the dryer are badly worn and/or the rear bearing is worn. From your description - the drum is sticking - causing the motor to slip on the belt - causing the burning smell.
Replace worn parts including the drive belt.
Aug 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
1180 cub cadet replaced both drive belts length of belts is correct,mower still moves if foot peddle is not engaged.per manual set the adjustment of the drive pullys and the problem is still there.I have...
If you did not use the original manufacturer belts it will cause this as lawn mower belts are designed to slip when not under tension (so called graphite Belts) where other belts are designed not to slip even when some tension is lost.
Nov 07, 2017 | Cub Cadet Street Sign- tractor lawn riding...
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
BELT ADJUSTMENT
There is an idler pulley near the drive pulley under the engine. It is made of plastic and is a common failure. It freezes up and doesn't want to let the belt move. Have you noticed the smell of hot/burning plastic? You can replace it with an original, but it is still plastic. Metal replacements can be had. I think I got some from mcmaster.com so try there. They are a great resource. Shipping is fast and inexpensive and they have everything a guy could want.
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
