Fuser error on samsung fax - can I forward the faxes in memory?
I have a samsung 6800 fax machine. It had received 20 plus pages of important documents which I need to finish a report for Court first thing on Mopnday!
Having received the pages it then gave the message ''Fuser Error''.
I don't seem to be able to get it to do anything now - there had been a message a day earlier warning that the toner was getting low so I have replaced the toner - no change.
Looking at postings found by Google this error suggests a fatal - and uneconomic - failure.
Therefore, I would like to extract the pages asap - can I perhaps forward them to another fax?
Suggestions please.
jeff
No you can't, have them sent to another destination for you -or emailed
Posted on May 17, 2009
Cannot recieve fax on hp pro 400
HI,
Set Fax Forwarding:
You can set your product to forward incoming faxes to another fax number. When the fax arrives at your product, it is stored in the memory. The product then dials the fax number that you have specified and sends the fax. If the product cannot forward a fax because of an error (for example, the number is busy) and repeated redial attempts are unsuccessful, your product prints the fax.
If the product runs out of memory while receiving a fax, it terminates the incoming fax and only forwards the pages and partial pages that have been stored in the memory.
When it is using the fax-forwarding feature, the product (rather than the computer) must be receiving the faxes, and the answer mode must be set to Automatic .
  1. From the Home screen on the product control panel, touch the Fax button.
  2. Touch the Fax Menu button.
  3. Touch the Receive Options button.
  4. Touch the Forward Fax button, and touch the On button.
  5. Use the keypad to enter the fax-forwarding number, and then touch the OK button.
If not solved i share a link please visit and follow instruction.
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c03266760-14%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1403114393261.876444892.492883150
Thanks,
HP Phone Number
Jun 18, 2014 | HP Photosmart C6180 All-In-One InkJet...
My fax is say ' fuser error ' then ' memory received'. What does this mean and how do I clear it? Andie B
Fuser error means the the fuser (the part that heats up and "fuses" the toner onto the paper) is not heating up properly. This usually requires the fuser to be replaced. The memory received indicator is telling you that the machine has received a fax transmission. It can not print it out however because of the fuser error. If the fuser is replaced then the faxes in memory will be printed.
Good Luck and Thank You for using Fixya.
Dec 08, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Samsung sf5100 fax shows "fuser error" and I cannot receive faxes but can send ok
The fuser unit will need to be replaced. It's possible that the heat lamp or thermostat of the fuser has failed, but getting those individual items could be difficult. The fuser unit should still be available from a Samsung repair center. Search on line for your nearest authorized dealer. You will continue to be able to send regardless of the fuser.
Jul 07, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
HOW DO I SEND A FAX ON THE BROTHER MFC-5440CN? LOST MY MANUAL
Remote Fax Options;
5. Press Stop/Exit.
Setting Fax Storage
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
these faxes.
PC Fax Receive.
Press Menu/Set.
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
the CD-ROM.)
Apr 22, 2009 | Office Equipment & Supplies
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung sf-6800 fax machine reading fuser error is this worth repairing
I would say no. It probably needs a new fuser unit. I would guess $200 plus labor.
Sep 12, 2008 | Samsung Office Equipment & Supplies
Fax machine
It is more likely that there is a setting or error... are you receiving any error msges or alerts when you try to fax out?
Just in case here are the steps to turn off fax memory
  1. Follow these directions to turn off the fax memory.
  2. Press Menu/Set.
  3. Press the up or down navigation key until Fax appears and press Menu/Set.
  4. Press the up or down navigation key until Remote Fax Opt appears and press Menu/Set.
  5. Press the up or down navigation key until Fwd/Page/Store or Forward/Store appears and press Menu/Set.
  6. Use the up or down navigation key to select Fax Storage (or Off if you wish to disable Fax Storage). Press Menu/Set to confirm your choice.
  7. Press Stop/Exit to exit the menu.
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
Will not print due to OPEN HEAT ERROR message?
Will need to have fuser replaced, guestimation is 150-200 for fuser plus 50-100 to fit
Dec 01, 2007 | Samsung SCX-5115 Fax Machines
Samsung sf6800 fax
Could be a cartridge problem.
Feb 23, 2007 | Samsung SF-6800 Plain Paper Laser Fax
103 people viewed this question
k24674
