Question about Maxtor Hard Drive
Maxtor hard drive
I took a maxtor harddrive out of a dvr,can it be reformated to work in a computer?
  • 696 Answers
Yes it can,
The drive will have to have the current partition removed and be re-partitioned and reformatted then it will be ready for use.
If you need more info regarding the procedure, reply here with your operating system and I can give you a little more info.
Chris
Posted on May 26, 2009
My Maxtor 1000GB harddrive has stoped working. PN:9NZ2D8-500. SN:2HBECHWY. It connects by a USB and powed by a transformer that was supplied by Maxtor. All of the parts are about two years old, brough
I replace my hard drives after 2 or 3 years. Yours seems to have quit early, possibly the transformer is not working. If your external drive lights up, the electronics could be bad. At any rate, the bad news is it sounds like time for a new drive. I hope you have a backup of the contents.
Dec 23, 2017 | Maxtor Computers & Internet
Backing up my Maxtor Portable Harddrive?
hi
visit www.fbackup.com and download the software to backup your data
Dec 26, 2009 | Maxtor Hard Drive
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
Oct 07, 2009 | Maxtor Hard Drive
I took a maxtor hard drive out of a dvr,can it be reformated to work in a computer? it's a fireball 3 ata/133 hdd 40 gb.
Yes it can,
you will need to either install it in a drive enclosure to put it on externally or you will have to install it inside your computer and connect it to the motherboard and power.
Once you're ready to go to the next step, let me know what version of windows you're using and I'll give you a short step by step.
Chris
May 16, 2009 | Maxtor Hard Drive
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Harddrive Disconnects
get a new external drive and transfer all the files to the new drive.
Jan 14, 2009 | Maxtor OneTouch II external hard drive...
Maxtor 3200 error code 10
I had the same problem and this is what I did.
Problem:
Working for 1.5 years and suddenly quit. Computer did not recognize the hardrive.
Code 10 trying to mount harddrive.
My hard-drive did not make any noise, just a silent click.......click....
Condition:
This worked for me under the situation that:
I used this external drive on my desktop.
I have an available slave connector and power.
I know enough about the inside of my desktop to install a slave drive.
Solution:
Removed the drive from the box, and attach to computer Desktop as slave.
1) There are some slider latches on either lenth wise sides. Once disengaged top should come right off. Or just crack it open.
2) Once opened remove screws from metal Cage, and remove top of cage.
3) Remove three screws holding the USB adapter card. (All visible screws) Not the ones on the actual hard drive.
3) Carefull remove harddrive and the attached usb adapter card in one piece.
4) Remove the USB adapter card from hard drive.
5) Turn off computer to be installed, and unplug. Install drive direct, as slave. No jumpers to move since the drive is already set to slave.
6) Plug computer to test and if it is read and mounted, your ready to go.
7) turn off computer, and unplug. arrange cables in desktop case.
9) Close up the service panel and plug your computer back up.
I need to be sure before sending it in for recovery and spending $800. So I connected as slave to 2nd desktop computer and it mounted. This means that the "USB adapter card" that came with the maxtor3200 was faulty. It was recommended that the best way to back up on another harddrive is to directly plug your harddrive into your computer as slave.
Good Luck!
Copy-Cat
Aug 26, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
My maxtor one touch II enxternal will not paower up!
I took out the harddrive and put it internally into my G5 tower and it worked.
Apr 15, 2008 | Maxtor OneTouch II external hard drive...
Maxtor Hard Drive Logo
113 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
