Question about Acer Aspire 3100-1405 Notebook
Acer 3100 laptop running windows xp, my USB ports are not working
You can see a thumb drive plugged in, and then it goes away, you can go to my computer, and see the device, but it won't read it. Is this a driver issue?
  • gwenbradleya May 17, 2009
    Hey, I still have the problem, guess I didn't make myself clear- The USB ports are seeing any device, and then they are not. They just blink off and on, and will not recognize them????
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
No my repair shop see's this alot. All my employee's use thumb drives religously in our shop. I see this happen often esp if it gets used alot. I have even seen this happen when its removed while shutting down the PC. It is possible to attempt to reformat the thumb drive. If you unsuccessful, get a new thumb drive.
Posted on May 16, 2009
I have Samsung R590 Laptop which i bought December last year... Before the USB ports used to work properly and display wt ever data is present in the usb ... but now it reads the data but all appear as...
Microsoft Knowledge Base
Article 971029
describes an update to Autorun that restricts AutoPlay
functionality to CD and DVD media. This update is intended to stop AutoPlay
functionality from working on USB drives, external hard drives, or network
shares. This update is available for supported editions of Windows XP, Windows
Server 2003, Windows Vista, and Windows Server 2008.
Removable USB/thumb drives use the Autorun feature to load files when the drives are plugged into the USB port. Malware exploits the Autorun feature to spread from thumb drive to PC. Disable the autorun feature to prevent malware from spreading.
The preceding describes what has likely happened to your USB ports due to Windows update disabling the autorun feature for USB thumbdrives. The thumbdrive may no longer present its data properly unless you manually invoke the autorun in its root.
Mar 27, 2011 | Computers & Internet
I reinstalled my OS win XP . now no usb
Open Run and launch regedit
Browse to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR
In the right pane, look for an entry named Start. If you find one delete it. Your USB devices should start working immediately.
If not please report back.
Nov 11, 2009 | Acer TravelMate 240 Notebook
Acer USB Ports - Unknown Device - Will Run Mouse but not Printer
Sumtimez ports r damaged.somtimes not.. just chek other devices..if done..thn chek RAM!! lil chance tht u hv lost ur laptop!
Oct 12, 2009 | Acer Computers & Internet
I have and Acer Aspire 3100 And im running a VISTA system, the usb ports have stopped recognizing everything, from web cams to ipods and flash drives. How do i fix this?
Go into the Control Panel, System, Device Manager.
Right-click the usb ports and choose uninstall.
Reboot the computer.
That should do it.
Jun 15, 2009 | Acer Aspire 3100-1405 Notebook
USB ports and memory slot Quit working
Can you access the internet...??? If yes then... run windows update [Control panel>Windows Update] on left-hand side...!! When you access the web page for windows xp update [Run Express update] and it will search for the latest driver updates for your computer.
Then restart computer!!
Any problems then, email me at: encaptured.media.ltd@googlemail.com
Apr 15, 2009 | Acer Aspire One PC Notebook
Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Oct 20, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Usb ports do not active
One of the great features of USB devices is they can get power from the USB port. Plug in a thumb drive and it just works. The power for operating the thumb drive comes from the USB port. This works for small devices like a thumb drive but not something big like a scanner. The scanner need its own power supply.
There could be several explinations for what you are seeing. Could be you are plugging in a device which is sucking too much power and the laptop is shutting it down. I would test the port with something small like a thumb drive and see if it works. If the thumb drive works but the other device does not a couple of things could be going on. Maybe the device just need power - is there a way to plug in a power supply? Or maybe the device is broken and shorted out. Does the device work on another computer?
If something like a thumb drive does not work then it is a problem with the motherboard. Could be the USB ports are bad. It happens and there usually is no easy fix short or replacing the motherboard ($$$). Occasionally there is a BIOS setting for the USB ports. A bit of a long shot but worth a look.
A possible work around would be to get a power USB hub. A hub plugs into a USB port and provides 4 or 7 USB ports. Good ones come with a power supply. When the hub is plugged into the power supply it does not draw power from the computer. Might solve your problem.
Aug 23, 2008 | Acer Computers & Internet
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Cd drive/ USB/ reinstall XP
Nifty little IDE to laptop ide adapters on ebay for under $10 delivered..
remove laptop HD.. use adapter, plug into desktop as second drive.
Load up XP install to a folder.. use a decent file copier so you get hidden files. try filesync 2.xx (look for it),
Back into the laptop, try it..
Only other thing would be LEGACY USB SUPPORT in the bios and an external usb drive... Hopefully your usb problem is XP related and not hardware related..
Feb 12, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3100-1405 Notebook Logo
228 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
