Won't power up
TV won't power up. viewing from front when is plugged in red light comes on for a few seconds then go out. Viewing from the back with back cover removed, when plugged into power, a couple of green LEDs com on for a second or two then another green LED come on for maybe 1/2 second then all LEDs go off. Nothing else happens.
Please help.
  • ddeberr Oct 18, 2007
    Sorry about that. This is an Hitachi Mod. # 60UX588. I will check the pico fuses. Kids could have been pressing on-off button a few times. Thanks for the suggestion.
                                         Thanks
                                                 Don
  • ddeberr Oct 25, 2007
    Have not had a chance to try solution yet. Have moved since I posted the problem. Will try solutions when we get everyone settled in. Thanks
    Genius:
  • 1,694 Answers
C702 102K / 2KV capacitor shorted,located near transformer,
possibly partly covered with glue.Use Sony part # 1-161-754-00
102K / 3KV for replacement. Check E994 pico fuse ( 2 amp ).
Let me know by rating my suggestion....T.
Posted on Oct 22, 2007
  • Vista Electronics Oct 22, 2007
    P.S. your model # is 60UX58B.
  • Don DeBerry Aug 18, 2011
    I apologize for the 4 year delay. I replaced the E994 pico fuse, Plug tv up, C707 not C702 blew out. Could not read value on C707, So I replaced it with 536K 2KV. cap. TV works but I think its the wrong value (536K) because it looks like a vertical raster problem.Could tot find a C702 in that area. I will replace C707 with a 102K 3KV cap. Will keep you informed. Will do my best not to allow 4 years to pass.
    Thanks
    Don DeBerry
How to repair tv
Posted on Jul 01, 2012
    Problem Solver:
  • 11 Answers
It would help if we knew what kind of tv it is it sounds like an hitachi if it is check all the pico fuses if one is open something caused it to open and you will have to find out what caused the problem... if it is not an hitachi let us know what kind it is...
Posted on Oct 17, 2007
Panasonic plazma tv th-42pd50u. Red light automatically turns on when connected to power and stays on. No clicks, No blinks and No picture. Is this a faulty power supply board?
possible reasons, its in standby, hold in the proper ON button on the tv for up to 20 seconds gently. or try disconnect power(pull plug out) wait 10 seconds, plug back in and turn on using the actual button(holding for up to 20 seconds) NOT THE REMOTE if that does not work, make sure your INPUT is CORRECTLY selected eg you are viewing HDMI1 and NOT HDMI2 for example. there may be different procedures for flashing lights
Dec 12, 2017 | Panasonic Televison & Video
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
