Question about Maxtor Hard Drive
I took a maxtor hard drive out of a dvr,can it be reformated to work in a computer? it's a fireball 3 ata/133 hdd 40 gb.
  • Anonymous May 25, 2009
    ok im running xp pro,my computer see's the drive but give's an error cant read this drive? how can i wipe this drive and start with a fresh copy of xp pro?
  • 696 Answers
Yes it can,
you will need to either install it in a drive enclosure to put it on externally or you will have to install it inside your computer and connect it to the motherboard and power.
Once you're ready to go to the next step, let me know what version of windows you're using and I'll give you a short step by step.
Chris
Posted on May 24, 2009
  • grimeshenry
    grimeshenry Jan 14, 2013
    Ok Chris and then ?
I am do the clean in hard driver in clean in bad sector.
Thia is called the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
May 03, 2011 | Maxtor Seagate Fireball 3 40 GB ATA-133...
How do you set the jumpers the Maxtor Quantum Fireball Plus AS 20.5 GB hard drive
Jumper settings for Seagate and Maxtor IDE (ATA) harddrives,
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=196299&NewLang=en
Follow the chart examples under the second heading down >
Maxtor (and Quantum) drives follow the jumper configuration noted below.
If I may also add;
1) http://www.youtube.com/watch?v=Ds1-JmbhGRM
2) http://www.youtube.com/watch?v=WwbboeMO7b8&feature=channel
Nov 10, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Problems with my hard drive
You should be able to slave the old harddrive to the new one regardless of manufacturer. In the event that the drive is not "browseable" via Windows explorer, you should still be able to use DOS commands to copy the data files from the old harddrive to the new one.
Mar 27, 2009 | Computers & Internet
HDD unable to detect at My Computer
Well first I would pull the hard drive out of the case. I would then get a USB to IDE/SATA drive cable. I would connect the drive not being able to be detected to another computer via USB.
If it works the drive is still good but the data might be corrupt. If the data is corrupt I would be sure to get any stuff you can off of it and basically reformat and reload.
Mar 13, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
What 2nd "Slave" hard drive should I buy to match my "Master"?
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Dec 29, 2008 | Mobile Rack - 3.5 Inch Hot-swappable...
Maxtor Hard Drive Logo
136 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
