Question about Magellan Maestro 3200 GPS Receiver
Need clarification please
Does "Plug the end of the cigarette lighter adapter into a 12 VDC vehicle power receptacle" mean
plug the cable into the cigarette lighter socket?
    Sergeant:
    Champion:
  • 387 Answers
Yes it does.
Posted on May 16, 2009
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Jun 28, 2014 | Power Center Jumpstart 11-411
LINCOLN NAVIGATOR AIR SYSTYM NOT WORKING
Check the fuse panel to ascertain the fuse to air system is not blown. If fuse had blown, did you recently plug an accessory into 12-v cigarette lighter? Its likely the air system and cigarette lighter plug are on the same circuit.
Nov 20, 2013 | 61302V Barometric Pressure Sensor 0-5 VDC
Is there an adapter that can be used on a car cigarette lighter for plugging in appliances?
Your best bet is to check on eBay for an adapter - the Asians make all sorts of stuff for cars now & i'm sure there is an adapter out there suited for your purposes. P.S. It may sound silly but are you sure you are using the actual cigarette lighter socket & Not a power outlet socket that many cars are now fitted with as standard?, my phone charger fits the cigarette socket but not the power outlet?, you never know?
Sep 13, 2012 | 2004 Kia Rio
Hello. I have a problem that no one has seemed to be able to help me with. All i get is a dumbfounded look or scratch on the head. I have a Garmin Nuvi 780 GPS for the car. I do not have a cigarette...
Hi JoAnn, What you really need is a cigarette lighter socket in your car and this doesn't have to be a big problem. In most car accessory shops you can get cigarette lighter socket splitters, like the one at http://www.amazon.co.uk/Silverline-Cigarette-Lighter-Splitter-Adaptor/dp/B003TNYK7Y/ref=sr_1_1?ie=UTF8&qid=1301407423&sr=8-1
Now I know these are supposed to plug into your cigarette lighter socket but you can remove the plug from the end of it and get wired directly to the fuse board of your car. The wire that goes to the centre tip of the plug connects to the positive/fuse of the fuse board and the wire that's connected to the outer part of the plug connects directly to an unpainted metal part of the car. You can do this by loosening a bolt, wrapping the wire around it and tightening it again. The block with the sockets on it can be either glued with double sided tape to a convenient part of your car interior or left loose if you prefer.
If you're not happy wiring it directly yourself it should not cost a lot to get done in a garage. If I was in your position that's what I'd do.
Mar 28, 2011 | Garmin Nuvi 780 4.4 in. Car GPS Receiver
Car adapter not working, i can power unit from usb. fuse is good on car adapter and 12 volt outlet is working. can i test tthe power out of the adapter?
The only way to test the car charger for the 765T is with another satnav. However the problem is most likely that the fuse in the plug of the car charger is blown. Near the top of the plug, that goes in the cigarette lighter socket, there's a ring. On most plugs it's silver but it's black on some. Unscrew the ring and the plug comes apart. Be careful not to lose the silver nipple at the end of the plug. When you take it apart you will see the fuse. Replace the fuse and the problem should be solved.
Oct 16, 2010 | Garmin nuvi 765T GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Can not figure out how to charge the Vector start it pro
Easy, just insert the "cigarette lighter style" plug from the A/C charger into the "cigarette lighter style" socket on the top of the unit, and then insert the A/C adapter in to a wall socket. It can also be charged in your car with a cord that has double "cigarette lighter style" plugs at ether end, one inserted in the Vector and the other in your cigarette lighter.
Wait, one more - clamp the units cables properly on to your cars battery terminals, then start your car. periodicly checking for full charge.
Hope it helps... Good luck
Feb 21, 2009 | JUMP START SYSTEM
Garmin Nuvi 300 does not switch on. The wrong charger was used
1. If using the power/data cable to power your device:
  1. Make sure you have power at the source it is connected to.
  2. Check the fuse in the power cable.
  3. Use a volt meter to test the end which plugs into your device (the manual for the device should show which pins are power and ground. Make sure you are getting at least 12 volts of power. This will ensure you are getting full power through the cable and determine if the cable is faulty.
2. If using a 12 volt cigarette lighter adapter:
  1. Check the fuse in the adapter.
  2. Make sure the cigarette lighter in the vehicle has power by connecting another device with a different 12 volt adapter if possible.
  3. Make sure the metal tip on your 12 volt adapter is still connected
3. If using batteries:
  1. Make sure none of the battery terminals are still connected to the device.
  2. Try new batteries.
  3. Make sure the batteries fit tightly inside the device. This will ensure the battery terminals are not loose and you have good contact.
4. If you are powering the device on the built in lithium ion battery:
  1. If you have a power cable for the device, plug it into a power source and see if the device will power on with direct power. If it powers on, check to see if the battery is fully charged.
  2. If it is not, let the battery fully charge and then try to power it on with just the battery.
Sep 26, 2008 | Garmin GPS
Rwr supply
Buy an adapter such as the one in this link to convert AC power to a 12V "cigarette Lighter" outlet.
http://www.amazon.com/Universal-Cigarette-Lighter-Socket-Adapter/dp/B000EG8RIM/ref=sr_1_5?ie=UTF8&s=wireless&qid=1207184215&sr=8-5
Feb 06, 2008 | Audiovox PVS72901 Portable DVD Player
Replacement parts
algae: Car Adapter PN is S0535 for $28.75 without S&H and you can find it at: www.vancebaldwin.com Direct link: https://www.vancebaldwin.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5646537&smodel=MPD850 SithPitt
Jul 04, 2007 | Philips Magnavox MPD845
Magellan Maestro 3200 GPS Receiver Logo
75 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
