Question about Sony Playstation 3 (PS3) Console
Controller, somethin' like that.....
My controller has stopped working.....i charge it almost everytime i use the ps3, but i turned it on today, and it doesn't even light up.....i reset the controller, and nothin'......HELP ME PLEASE......
  • 709 Answers
Hi BUB07,
I know you want this thing to work bad. You will get better help out of Sony that what I am going to tell you. Call 1800345 7669 and get it fixed.  If you do not want to call sony and want to attempt a near impossible repair. Here we go. Go find a table on a a floor that is not carpeted.REmove the screws that hold the case together.
  • Look where the wies connect to the main board in the middle.
  • look for Bad solder joints, and if you find any REsolder these.
  • Put it back together and test it.
  • Done.
  • Sony has been having a slight problem with the Soldering in the PS3 era, you may get  lucky and find one. But, you wil void your Warranty.
please do not press anything less than solved here, as if you press anything less, you will not have the opportunity to return and change it to Solved.  This is a Free tip, please give it a solved Vote.
Posted on Oct 16, 2007
My dreamgear chargepack works but when I but my sliver remote control in it lights up which means that its charging but when I try to charge my blue control the lights wont turn on. how do I make the light...
I have several controlers in several different colors, but "coincidently" several of the blue colored controls have had the LED lights stop working completely. I am begining to think that many blue colored Sixaxis PS3 controlers were made during a version that had problems with the LED lights going out and no longer working, or simply a bad batch of controlers.
Did you try letting it charge for a while, even if the ligfhts won't light up, then press and hold the PS3 button to check and see if it took the charge?
On my blue controlers, they still charge and still work, but none of the LED lights illuminate anymore.
Solution would be to buy a new controler, or ignore the lights not working.
Sep 20, 2013 | Video Game Consoles & Games
My ps3 controller is not working or charging and everytime I try to charge it it always says charging failed
if the light isn't flashing 1 of 2 things the usb cable is bad or the battery is done try another cable or plug in another controller and see if it charges that would rule out the cable ..Hope this helps
Apr 20, 2013 | Video Game Consoles & Games
My playstation 3 : everytime i turn it on it goes green then back to red and wont turn on? When it was working it just froze so i turned it off and since then it hasnt turned back on
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning .
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Ps3 conntroller does not charge or flash when ps button pressed
theres a little hole on the bottom of ya controler get somethin small and press the may also need a new controlers did that to now one of mine to day went wacko on cod 5 when i moved the ps button wasnt pressed but the screen still poped up then it wasnt responding correctly it made me go like this stand crouch lay down crouch lay down stand up and kept on doing it its going to affect my freinds playing when he plays splitscreen with it how do i fix it!?
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
Controller won't turn PS3 console on
your console forze up take it to your nearest game stop and tell them the problem
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
May 10, 2009 | Sony Dual Shock 3 Controller for...
We have an Intec G7789 Infinite Play wireless controller and we can't get it to work with our PS3. We have tried everything that the instructions say but it won't connect.
I dun really know how I did it, I had the same problem as u guys. And I try all sorta method.
  1. the last method that I tried was to leave my USB receiver thing in and then restart my ps3. With my controller turned off.
  2. After the PS3 restarts, I turned on my controller.
  3. Then I pressed the home and link button together. And those 4 lights on ur controller will flash really fast.
  4. Then I replugged my USB receiver, and the controller light will flasher a lot slower.
  5. Then just press "home" and the controller should sync with your PS3.
  6. And after that NEVER remove ur USB. LOL. After that, everytime u turn on ur PS3 just press the home button and the controller should sync with ur PS3.
  7. And remember to always to turn on ur PS3 before u turn on your controller.
Well that's my solution, if it doesn't work for u then sorry. Get a refund. I was planning to get a refund but then everything luckily worked out. Good luck and keep trying.
Jan 12, 2009 | Intec PlayStation 3 Infinite Play Wireless...
Ps3 controller
everytime you play the Ps3 and you try to play a game it loads and you have to press the PS3 button again.
click the Thank me Button XD
I helped all i can
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
