Question about Ovens
F3 error in roper model B9757XO
I have a dated built in roper double oven. Model #B9757XO. My husband was cooking pizza and it got excessively smoky and the oven went off with an F3 error in the display and a fan that now continuously runs. Can it be reset? The was the top self cleaning oven. The bottom oven work. Help.
  • 6,784 Answers
Hi. This F-3 code is representing a malfunction within the oven temperature sensor. It is open at the moment and unable to transfer data at this time.
You can test by Measuring the oven temperature sensor resistance, should be1100 ohms. If not, replace sensor.
Posted on May 16, 2009
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
Jun 22, 2012 | Hotpoint Ovens
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Oct 25, 2011 | Ovens
Whirlpool Gas Range SF357PEKQ0 -- over heats; will not shut off; have to turn off at gas line behind stove. Error Code: F3E2. Is the replacement part I need the thermostat sensor? Is this part easy enough...
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Thank you for using FixYa.
Nov 22, 2010 | Whirlpool GBS277PDS Electric Single Oven
I have a Roper electric over B9757XO that when you
probably a bad oven control board. check the lock switches too while you in there messing around getting lit up lol
Jul 28, 2010 | Jenn-Air JJW8530C Expressions Collection...
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
150 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
