Question about HP Pavilion dv4000 Notebook
Touch pad isstP Pavilion cursor starts drifting uncontrollably
I'm running into touchpad problems with my HP Pavilion dv41212i whenever I have the battery charger plugged into the laptop. When plugged in, the cursor starts drifting uncontrollably and automatically clicks the screen without me lifting my finger from the touchpad. If I unplug the power plug and run on battery, the touchpad works perfectly. Anyone know how I can solve this annoying issue with the touchpad? Basically the touchpad is useless when power is plugged in. I'm running Vista 64-bit with all the latest touchpad drivers and firmware.
Try removing your battery and replace it back. its like resetting it.
Posted on Jun 26, 2009
While typing cursor jumps of to different lines and different areas
If you are using the touch pad, try turn it off and using an USB mouse. I have found that my palm hits the touch pad and causes random cursor movements.
May 12, 2011 | HP Pavilion dv4000 Notebook
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
The touchpad is installed on HP notebook PCs.
You can "tap" and "double tap" your touchpad with your finger, and interact with the operating system in exactly the same way as clicking and double clicking on your mouse.
When using touchpad on your notebook PC, the cursor may jump, flicker, or double-click by itself.
Follow the recommendations in that HP document, or "disable" the TouchPad, if you don't like what it does.
May 12, 2010 | Computers & Internet
The cursor of my toshiba satellite has gone out of control. It keeps on jumping uncontrollable when i attempt to use the touch pad. I can only use the mouse. Please help
try to check your touch pad without AC power i mean run your computer on battery if your touchpad working ok on battery so there is a problem with your adapter ampere ask any local repairing center to check your adapter ampere or change your adapter and do not purchase compatible adapter, compatible adapter can not resolve your touch pad problem go for original adapter from toshiba
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | Toshiba Satellite A20 Satellite A25 Series...
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
Pavilion tx2110 touchpad jumps by itself
1. Its a normal thing, don't worry about it! (It happens mostly when you are using optical mouse.)
2. You can reinstall your Touch Pad / Mouse driver if you wish!
Jan 05, 2010 | HP Pavilion Tablet Notebook
My hp g60 cursor doesent move at all.
If the cursor doesn't move when using the touchpad, make sure the touchpad is turned on. There is a button right above the touchpad with five lit-up dots above it. If the dots are white, the touchpad is enabled -- if they are orange, the touchpad is turned off.
Hope that solves your problem!
Nov 22, 2009 | HP Pavilion G60-120US NoteBook
Cursor unstable on the screen
use a external mouse and see if the problem solves
if the problem solves then you will have to replace your touch pad.
Feb 08, 2009 | Computers & Internet
No cursor control
U may have to reinstall ur touch pad driver
otherwise use external mouse and then check it out
otherwise uninstall ur touchpad drivers then install it
Jan 20, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv4000 Notebook Logo
525 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
