Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy Built 320BV leaf blower (two identical ones, actually) won't start and have less than 5 and 20 hours on them. not getting a spark with the spark plug out, but with a non-descript plug, it will jump a 1/8" gap. Checked plugs and bought new ones - all okay. When push the fuel prime button 10 times, on choke and follow directions for starting, plug remains dry. Won't start even, briefly if we put gas in behind plug, either; also is there a carb. adj. screw and if so, how many turns to be open?
  • 1 more comment
  • libbymacd May 18, 2009
    so, that might address the problem of no fuel on the spark plug after priming, but not the fact that there is not spark across the plug (the relatively new one that came with the blower, or brand new one - tried two different equivalent brands) when it's out, but do get a spark with a non-descript plug -that's the case with both blowers
  • libbymacd May 19, 2009
    that's exactly what we have already done and with the spark plug that came with the blower and a new one, we don't get a spark, but if we use a non-descript plug, we get a spark that will jump a 1/8" gap (see my original comments above) The man who is trying to help me can usually fix ANYTHING and happened to already have an identical blower in his shop that he hasn't been able to start, either. I mean this man is amazing and that's the only reason I tried this site because I was unprepared for him not to be able to fix it - thanks for your help - any other suggestions? We can try the fuel tank idea, but he said we should at least be able to get it to start briefly when he squirted gas into where the spark plug goes and put the non-descript one in there - the one that will spark - no luck
    no - it WON"T start when pumping prime bulb or squirting gas in the carb. - that's the second part of the problem. If we could at least get it started that way, we would know it was only a gas supply issue, maybe. We are NOT getting a spark with the installed, or new spark plug - but can use a non-descript one and get a spark that will jump a 1/8" gap! Weird, weird.
  • 355 Answers
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Posted on May 18, 2009
  • 3 more comments
  • Rohit  Asthana
    Rohit Asthana May 18, 2009
    I suggest you open the fuel tank and "fish" up the fuel line hose with
    the filter attached. Simply blow out the filter. That should allow your
    engine to get necessary fuel to carbuetor. This is 90% of today's no
    start problems.
  • Rohit  Asthana
    Rohit Asthana May 19, 2009
    1st how old is the gas and 2nd how long did it sit for since you last
    used it? If there was any old fuel left in before now (more than 14
    days) than it is possible your carb needs cleaning. If it's less than
    14 days then you might want to check the compression. IF you have good
    compression, then you might want to take it to a service center to have
    it diagnosed.
  • Rohit  Asthana
    machine will only start when pumping primmer bulb or squirting fluid in
    the carburetor than stops. the fuel line has broken off, in most small
    carburetors this is a ongoing problem.old fuel will crystallize when
    left in tank for a long time.plugging up ports, fuel lines, small
    screen in carburetor.fuel lines will dissolve clogging carb.also the
    gas will evoporate leaving the oil behind clogging up carb.the thing to
    do is remove carb. and clean out,replaceing gaskets or fuel line if
    necessory.use carb cleaner to clean out carb.make sure to make note
    where fuel line go.the fuel filter broke off of fuel line letting
    debris get in carb plugging it up.the muffler is known to clog up a lot
    on these machines where thay want run. the compression should be 60 to
    120 lbs any thing below 60 is junk. when adjusting the carb screws turn
    in all the way than turnout 1 1/4 turns turn in slow untail machine
    runs also you need to check for spark by removing plug and grounding
    aginst engine to chech spark, ok.a new spark plug would be a good ideal
    too , if you are going to make these repairs use new fuel line and
    filter,hope this helps
  • Rohit  Asthana
    You need to check for spark first. It should be able to jump a 1/8"
    gap to ground if the ignition system is OK. Also, when you try to
    start it, note whether the spark plug comes out wet or dry. If it's
    wet, the problem is most likely ignition. If it's dry, the problem is
    either carb or compression (leaking valves, etc.). Let me know what
    you find.
  • Rohit  Asthana
    If the ignition is functioning correctly, it should be able to jump a
    1/8" gap to ground. Make sure the ignition module to flywheel gap is
    0.010" and check for proper spark. If it has weak spark still, the
    problem is with the ignition module and it will need to be replaced.
  • 3,230 Answers
You need to clean the fule tank at that time, and i think that will sure fix your problem.
Good luck.
Thanks
Posted on May 16, 2009
Troy-Built blower fan off centre
Fan may be worn where it sits on the shaft. May need to replace it.
Aug 28, 2013 | Troy-Bilt Troy-built Tb2bpec 27cc 2-cycle...
My troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
My Blower dies after about 15 min. Then it will
I think its the ignition module. To test the module put 2 spark testers inline with each other and see if it will jump both.
If you dont have 2 testers then use it till it dies and try to start immediately with a prime. If it wont start then module is suspect.
Most manufacturers have lifetime warranty on thier modules ( I am unsure about MTD) so double check before you just go out and buy one.
Jan 02, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Aug 10, 2009 | Troy-Bilt Garden
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Wont start, not getting fuel, checked lines,carb and used starter fluid, runs but won't continue to run
You may need to do a more detailed cleaning on the carburetor. I like to use a Den Tek Brush, (used for cleaning teeth), to get into the small ports. They work great for this job. You may also need to check the small screen in carb. It gets blocked with debris.If you need further assistance, please contact me.
Jim
May 17, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Hello, My 31 cc troy built blower won't start. It's got spark. When I pulled the brand new plug it appeared to be completly dry. I sprayed ether in the cylinder and put the plug back in and it started...
If the either burned, then you have a fuel problem. Make sure the fuel filter (in the tank) and the lines are all clear. If so, then you my need to rebiud the carburator.
Jan 19, 2009 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Troy built leaf blower
Nov 18, 2008 | Troy Bilt 31cc Quickshift Blowervac, Model...
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
629 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
