Question about GE 25932 Cordless Phone
Interference with LinkSys WRT350N
I bought this 5.8GHz phone specifically to avoid interference with my 2.4GHz WLAN. However, when I make calls on the phone, my WLAN will often just die, all PCs lose their connection. If I hang up it comes back. Alternatively I just restart the WLAN and it presumably picks another frequency and works. I can't keep doing this. Why am I getting interference anyway?
  • mgclayton Nov 05, 2007
    Thanks for the suggestion. I did try it, with some small success.
    Whilst on the phone today, I lost my wireless signal, so I moved the phone base away from the router. It can't go too far though as I have an Internet phone. I got a small wireless signal back, but this fell away again when I tried to connect to a site.
    The only thing that allowed me to get a good connection (whilst on the phone) was taking the radio band off Auto and specifying a channel.
Try seperating the WLAN access point and the phone main station as much distance as is possible and try again. Your problem could be related to their proximity.
Posted on Nov 04, 2007
Interference engine
all Mercedes engines in my autolab timing chain book specifically state "do not turn the cam or crank" and some engines require the crank to be at 40 degrees to avoid valve/piston contact. So if you work on the idea that it is an interference engine then there would not be a problem. Changing the chain on all the various engines requires specific tools and procedures and unless you have access to these tools and specifications then it may be best to use accredited Mercedes trained service shops.
Apr 23, 2014 | Mercedes-Benz Mercedes Benz A Class Maisto...
I have three wall plugs two connected direct to individual TELSTRA phones Third wall plug connected direct to DLINK Modem and via filter to Engin Linksys line socket Then DLINK to Linksys...
It sounds like you have interference on the line, and your mailbox for your phone is not set up, or functioning correctly.
You need to call your phone Company/Provider to have this resolved.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 15, 2014 | NEC Lands Phones
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
I have a Broadcom 802.11g Network Adapter and a Cisco/Linksys WRT54GS Router. The signal is extremely poor even though the router is only 10 feet away. It does not appear to be an interference issue.
You can update the Linksys Firmware to a newer version if is available, please check the Linksys support site
Another chance is to change the Wireless Channel maybe 11, to avoid any intereference with wireless phones.
Mar 13, 2011 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Weak signal recption
Since wireless networks use radio waves to transmit signals, it’s possible that typical household electronics-your microwave, cordless phone or even the baby monitor- can interfere with this signal. Make sure you move your wireless router away from those devices that use the same 2.4GHz frequency range.
Other causes of interference are brick and cinder block walls, metal doors, metal frames around windows and doors, and metal filing cabinets.
Take these simple steps to reduce wireless interference:
  1. Move the router further away from the interfering device or object.
  2. If there is interference with a phone, you can change the channel of the phone or the Router so they use different channels. If there is still too much interference, you may have to buy a different phone system, operating at either 900MHz or 5GHz.
  3. Place the wireless router in a central location of your house, such as a family room or office.
  4. Arrange the desktop or laptop’s wireless antenna so that it points toward the wireless router.
  5. Avoid placing the antenna close to an outside wall (unless outside is where you want to be). If you want to connect while you’re outside, place the router near a window.
  6. Place your Access Point as high as possible. If your network goes through multiple floors, try to place the Access Point on the upper floor
Oct 04, 2009 | Linksys Computers & Internet
Interference on opposite phone. Cect I9
I have this same problem - see hints it is about interference with the microphone. Using bluetooth avoids the problem - anyone know the fix??
Feb 26, 2009 | Dual Electronics CECT P168 Cellular Phone
Switch to Switch Connection
This is a very specific problem that requires a site visit to solve, there are many factors that can effect the transmission of data over a run of that length. There are many solutions to this problem, they range from rerouting the cable run to avoid sources of interference to selecting another medium such as WLAN or IrLAN. The specific implementation of the solution must be custom tailored to the situation, sometimes the solution requires equipment that is readily available on a store shevle and sometimes the solution must be engineered to accommodate the needs.
I would recommend looking at the cable route to see if it runs past any major interference makers (copiers/large office machines, industrial equipment, power equipment). Then look at the possibility of an intermediate repeater/router (protected location and availability of power outlets). Another possibility is a wireless technology, the specific technology depends on many factors. If you need high speeds or large data transfer, perhaps an Ir (Infra-red) link or WiMAX (802.16) would be best. If general purpose network connectivity is needed, then a standard 802.11 a/g WLAN will suffice. I recommend that you contact a local networking firm for a detailed consultation. Another resource that might be a better fit for most small budgets will be to contact the local college/university that has a well defined IT program to solicit members of the Alumni in a networking degree field.
Jan 06, 2009 | D-Link Computers & Internet
Interference phone line
Lots of different devices may be interfering with the transmit side of your phone. In today's world of heavy radio frequency usage by consumer devices it is hard to know exactly what may be interfering with your cordless phone. Even some cell phones could be causing the interference. The 6.0 gig phones do not have that problem.
Nov 09, 2007 | GE 25932 Cordless Phone
GE 25932 Cordless Phone Logo
140 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
