Question about CyberLink PowerProducer 2 for PC
Drive or disk not ready
Every time I try to burn a specific project, a 1,5h video, avi, I get as far as the burn step, where I always get the "This drive or disk is not ready" error message. The DVD is recordable and empty, brand new, the drive is also working otherwise. I can use it with Nero for instance, but not with PP2G.
  • 2 more comments
  • Eastander Nov 24, 2007
    I have the same problem. I've gone to the Dell site and updated the DVD firmware and Intel chipset drivers. I've right-clicked on the drive in explorer, gone to Properties and then Recording tab and enabled recording - this fixed my CD write problem, but so far not the DVD one!
    Heard it may be that too many different DVD writers conflict?
  • shearer9 Dec 14, 2007
    I have the same problem when trying to copy my daughter's Nativity play. I just get the message 'Either this drive or this disc is not Ready' whenever I try to burn a DVD.
    I have tried burning by following the tasks in the 'Produce Movie Disk' option, and I have also tried creating an image in here and then using the Disc Utilities to 'Burn disc from image', but just get the same.
    Everything up to this point is fine, and the movie is great - I just can't create a disc from it!
    I have tried DVD+RW and DVD-R discs but it doesn't make any difference.
  • vintage40s Mar 16, 2008
    Same steps taken and very same problem! I didn't have this trouble before. What is wrong with Power Producer Gold?
  • jpezza Sep 12, 2008
    Same problem using pp3 gold.
  • 32 Answers
SOURCE: burning dvds
you are probably missing the correct codecs for what you are trying to do. easiest solution is to donwload something like ace mega codec pack. http://www.free-codecs.com/download/ACE_Mega_CoDecS_Pack.htm install and try again
Posted on Jun 25, 2007
SOURCE: Burning DVD's
What burner are you using? if your burner is a DVD -RW and using +RW media, you might have a situation there. Check your media vs device.
Posted on Dec 13, 2007
acdr
  • 1913 Answers
SOURCE: Msg: "This drive or disk is not ready" But it is!!!
install new dvd burner software.
Posted on Mar 24, 2008
SOURCE: Failure while importing videos
is it because i dont got the original version? so i can't import videos with more than 30min?
thank you
Posted on Apr 28, 2009
Siouxie
  • 100 Answers
SOURCE: PowerProducer3 'failed to add video file'
I solved this problem by using a different program as I could not resolve the error with the cyberlink software.
Posted on Nov 17, 2009
Conversion process error " Convert step got some problems. [257:0:0] " of 2 hr.5min Blu-ray photo and video content. Ruled out menu problems and AVI videos. I have checked and rechecked track struct
Are you running the process direct to bluray? or across a network? If so, it could be a problem with disk/network the not being fast enough disk or buffering.
Try doing your conversion to an ISO. Then burning the disk from the ISO.
Dec 17, 2014 | Computers & Internet
Mysterious "ring" on burned DVD causes playback to freeze.
Is the image preponderantly encoded in PAL? Majority PAL and some NTSC? Or fully NTSC? Used transcoding presets? Transcoded project before you built to DVD? Note: Always run "TEST" before burning (to save plastic trees)? Determined whether system or project is faulty? Tested the DVD drive? Tried burning using another application? Closed all background-running resource hogs and applications? Did the project size increase the capacity size of the disk? Used a lower write speed? Disabled startup items and services? DMA: enabled? Updated Windows? Media compatibility? System requirements attained? Updated your application? Solved the issue(s); then write it down and share it with others. Still having issues? Revert back to the computer's factory settings and rebuild, upgrade, or invest in a high-end system and buy the full version of Nero 9, with all the plug-in features....and so forth. If time is money, the latter solution is your best bet. If money is an issue, then it requires trench warfare - that is, much research, deductive reasoning and time investment to isolate your specific problem...start by analyzing your source, and then your target...cause/effect relationship...you'll conquer all problems, eventually...political machinations aside. Ye all be happy computing Chomskyites. Dr. Frank Kohnstein.
Oct 29, 2008 | JVC DRM10 DVD Recorder
How do I upload videos?
Hi Elisa, I was having the same problem with my MAC. I have a G5 tower. After much searching, here's what I found:
If you open up Image Capture and have this open when your camera is connected. You will be able to download everything, including AVI files. Once you've downloaded the file, open up iMovie. Import the file into iMovie. Do what you need to do and then you can export it as a Quicktime movie.
Phew!
Aug 11, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Aug 10, 2008 | Panasonic Televison & Video
Sansui VRDVD4000 format
I do not believe this player plays AVI videos, not to mention whatever codec you are trying to use.
Download VSO ConvertXtoDVD and convert your AVI files to DVD and then burn them to DVD-R (NOT DVD+R), the 4.7GB discs (single-layer).
This process takes a very long time, depending on the size of the movies you are converting, some 1-2 hours, some 8-24 hours.
I suggest buying a Philips DVD Player that plays DivX and XviD AVI files, they seem to be the best. You can just burn the AVI to any disc and it will play. [Most popular seems to be Philips DVP 642]
Cheers.
Jan 08, 2007 | Sansui VRDVD4000 DVD Player/VCR
CyberLink PowerProducer 2 for PC Logo
1,114 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
