Question about iiyama AQU5611D BK (Black) 22.2" LCD Monitor
Black screen coming out of a game
My E2407HDS is connected with DVI to Radeon 9500. When coming out of a game, I get a black screen. The Radeon is not able to wake the screen. Only PC reboot solves the issue.
  • tigerzeevi May 18, 2009
    Hi dww0642
    Thanks for your advice.
    I did what you suggested.
    Problem is still identical.
    Any more ideas ?
    [btw. I tried already many obvious things - must be something more fundamental, I guess]
    Sniper:
  • 79 Answers
I would highly suggest uninstalling the Radeon drivers, download the latest drivers for your card from the link below. Pick your driver here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
Please rate my solution, if it helps.
Posted on May 16, 2009
  • David Weaver
    David Weaver May 21, 2009
    I would then find a memory tester and test out your memory. or you could just try some different memory if you have some lying around. or if you have more than one stick try them each seperately. I seem to remember having a similar issue a few years back, and had to rma my ram.
Screen occasionallly flashes black for 1-2 seconds at a time winXP
is it intermittent or possibly this happen when you change some settings in your pc, try another monitor to isolate the problem, screen usually turns black in windows when you change some settings. you have good graphics why not upgrade to higher version of OS it is possible also that your encountering compatibility issues
Jan 30, 2014 | XFX Ati Radeon Hd 5450 1gb Ddr3 Pci...
Can't get my Iiyama Prolite E2407HDS out of test mode
from iiyama tech support (UK):
  1. Switch off the monitor.
  2. Connect all 3 input types with live connections (VGA + DVI + HDMI)
  3. Turn the monitor on.
It will select an input and display as normal.
I have tested this and it does work!
Good luck
May 25, 2012 | iiyama E2407HDS-1 24 inch LCD Monitor
Radeon 9600 is showing black and white picture
check to make sure monitor is pluged in all the way and check with another monitor. if no good check catalyst control center sharpness setting (if conecting via s-video) if not you will probably have to resolder the connections on the board
Aug 14, 2009 | Diablotek RADEON 9600XT Video Card -, ...
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Viewsonic vp912b lcd display will not work.no DVI
Yes you can but there should be an option in the monitor settings for DVI... Maybe if you go into safe mode and attempt adjusting settings for the ati for the dvi output, from what I hear that monitor is nice with the DVI option would be aa shame to lose that.
Dec 22, 2008 | ViewSonic VP912B (Black) 19 in. Flat Panel...
Error message for delta force game
check that it works on Vista first.
Then un-install anything you don't need.
Check that you have done the system requirements to RECOMMENDED, NOT MINIMUM.
And make perfect sure that your graphics card is at least 1 level better than the recommended one
(eg. ATi Radeon 9500= 1 lvl higher= ATi Radeon 9600)
Please rate me
Sep 14, 2008 | NovaLogic Delta Force: Black Hawk Down...
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Random Black Screen
i hate to say it, but that sounds like the card is bad.. your best bet is to go to their support website and find out about a manufacturers warranty and send it in.. not much you can do.
Jan 25, 2008 | Acer AL2016WBbd Monitor
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
iiyama AQU5611D BK (Black) 22.2" LCD Monitor Logo
122 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
steve morris
steve morris
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
