Question about E-Machines eMachines Monitor E15T4
Crackling and flickering of monitor continuosly
My LG crt monotor started crackling and flicker continuosly after there was a voltage overlod in the whole area. Some Television even lost their disply. but in my case my monitor started crackling and flickering....
Any body plz help me what sorts of things should i change in it. if any body knows plz help
  • 33 Answers
Somehow i dont think theres anything you can do for it, judging by what you said, the overload was way too much for the screen
so, solution, get another screen, and get a decent surge protector, might not do much but it may prevent this from happeneing again
hope this helps
Posted on May 19, 2009
How do I fix flickering and crackling
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Aug 04, 2014 | Sylvania Televison & Video
I have a Tevion 32 inch LCD (Model LCD3210id ), purchased from Aldi stores about 4 years ago. The screen has started flickering and it is making a slight crackling sound from the back. One, has anyon
Those sounds would be either your power converter/supply inside the TC or/and faulty cabling inside that has been worn out resulting in noises and flickering.
Dec 24, 2012 | Televison & Video
LG 37LB1DA flat panel TV
most likely the inverter board is faulty, I think this model has two of them, look on ebay for cheap replacement.
Mar 24, 2017 | LG 37LB1DA Television
L246WH Monotr makes a sizzling noise and flickers
Safety note: For best safety practice, unplug the unit immediately. If you want to try and diagnose and/or repair it yourself, at least move it to an open area free of anything that could flame up in case of sparks or a fire.
Mr. McLellen could be correct about the failing solder joints. Since the symptoms increase as the unit heats up, I suspect it is more likely an electronic component failure. The specific symptom you describe is common in transformers with electrical shorts or with a cracked frame. Insects may also be the cause. Some are specifically attracted to warmth and electromagnetic fields. To rule out insects, take sample whiffs around the vent holes on the back of the unit after it starts crackling and flickering. Electrical burns are distinct from most other types, especially roasting critters.
Oct 14, 2012 | LG L246WH-BN Monitor
A few months ago my LG Flatron L1900R monitor started flickering when I boot up my computer. It has become worse, to the point where it now flickers constantly.
From the information desribed, this means that your CRT monitor is going dead. Unfortuntly, there is no way to stop the flickering unless the monitor was replaced. I hope this has helped
Jul 05, 2011 | LG 700M 17" CRT Monitor
The tv looses audio completely, the screen flickers followed by a crackling sound. Any idea what repair it needs? is it junk?
You have a problem with your high voltage section(flyback transformer).That crack you hear is your high voltage(12k+)arching to grd.This trans. supplies voltage to diff. sections of the tv.That is why your audio is affected.That particular section has to be inspected by a competent repair person.
Feb 27, 2011 | Insignia NS- 27" TV27 TV
Flickers and crackling
This problem could be caused by bad capacitors or cold solder joints in the power supply circuits. The unit needs to be taken to a service center for testing and servicing. Hope this helps.
Apr 14, 2009 | Computers & Internet
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Nov 02, 2007 | Insignia IS 20" TV040919 TV
E-Machines eMachines Monitor E15T4 Logo
226 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
