Question about Dometic Rooftop RV Air Conditioner
No air is coming through air ducts
My hvac is working outside and the fan inside is working but not blowing air through the ducts and when i take the cover off the fan that blows air through the house the the air ducts have air flowing through them but when i put the cover back on it stops blowing air through does anyone knows whats wrong.
  • 80 Answers
The cover has a filter incorporated, clean the filter and see if it works. it might be so dirty it looks like a black sheet. the dirt is normal, if is filtered from the air we breathe and usually comes from car exhaust gases etc
Posted on May 16, 2009
  • 116 Answers
Filter could be stopped up on return air or coil frozen due to low charge
Fan on unit comes on but no cold air comes from the registers
several possibilities inside fan not running,dirty coil,duct work problem. turn tstat to fan on position see if it make a difference.
Jun 18, 2014 | Goodman Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
I have a Janitrol outside Package unit, Not sure of the year, the trailer is a 97 or 98, not sure and the problem is that when it gets colder outside, the unit does not blow hot air, it gets colder inside...
Sounds like uninsulated exposed duct work. You can insulate the duct work and check to see that your cold air return is pulling air from inside the trailer not from an outside source. If the problem is not with the duct work try setting the high and low limits for the fan up slightly. Normal settings are roughly around 150 on the high and 125 on the low.
Dec 13, 2010 | Goodman GMS90703BXA Heater
Auto air and heat in car does not work
Sound like your HVAC door from the blower fan is staying closed
and not letting any air blow through the ducts. You will need to
check the vacumm or electric actuator in the dash. If you can locate it,
manually pull the door actuator to see if it will open and let the cold or hot air get to the ducts to blow into the cabin. It's not really for beginners, but if you can actually get to the main door inside the dash, you might just have a broken vacumm line in the engine bay, that is
not actuating the door actuator. Check for any vacumm leaks, then if you find one, I'll bet you'll have your system fixed. Good luck.
Mar 28, 2010 | 2002 Mitsubishi Galant
R410a fan outside blows no air comes through ducts on the inside
the fan on the outsides job is to help reject the heat. listen to see if the compressor is running. It creates the flow of refrigerant in your system. Make sure your filter is clean and you may have to look at the evaporator(A coil). Its job is to absob the heat from your home
Dec 13, 2009 | Heating & Cooling
Inside the air is blowing, but the outside unit fan isn't moving at all. HOUSE IT HOT!!!
Two things; outside does the compressor try to come on? If not you may have a switch\Thermotat problem. Also make sure the breaker to the outside unit hasn't tripped. If it has tripped there may still be a problem after you turn the breaker back on. If it's only the fan that's not coming on outside you will need a new capacitor or fan motor and compressor(if the fan motor is replaced you should have a new capacitor also. If it has been intensely hot your unit might have just gotten overworked. Then resetting the breaker is all that is needed. If you have continuos resettings you MUST call a qualified HVAC Tech.
Jul 12, 2009 | Goodman CLQ36AR49 Air Conditioner
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Ac conditioner stopped blowing
do you mean the fan doesnt blow either or its just not blowing cold air? check your fuses under dash and under the hood
i can try to help you further with more info
Jun 14, 2008 | 2004 Acura TL
Dometic Rooftop RV Air Conditioner Logo
299 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
