Question about Ricoh Aficio AP3800C Laser Printer
HI I am trying to connect my printer via a router
    Problem Solver:
  • 6 Answers
You need to plug your comuter into one of the LAN Port and the Copier into another LAN port your Modem into toyr WAN port. Then you will need the IP of the router it should com along with the router Info and either be 192.168.000.1 or 192.168.0.1. add an ip spec range Isusualle use 192.168.000.120 this goes into your copier under network protacals in user tools. under the same area setup sub net mask 255.255.255.0 if you have already installed you Ricoh AP3800 Driver place the ip 192.168.000.120 again the 3rd set of numbers either .000 or .001 depending on your router. SO under start menu go to either printer and faxes or control panel right click on printer icon for ricoh AP3800 go to properties select the ports tab, Click add Port select Standared TCP ip Clickm the new port. Click next Add your IP adress for the Copier here. Click next Next window will have Generic network card so press NEXT and then Finished Close printer ports window and then click apply. This should get you printing
Posted on Jun 16, 2009
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
Hi All, I am trying to connect Toshiba e-studio 207 via local network but unable to make it work.
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Oct 28, 2017 | Toshiba e-Studio 232 Black and White...
Trying to network printer through my router
Hi John.
The best way to proceed is using the network printer software to install the printer, or using the printer IP to install the printer.
You can also try first to browse for a network printer using Windows add printer standard feature, and then selecting Network Printer. You find the add printer option in control panel.
Ensure that you have printer software available, the system will need printer drivers to install the printer.
To start I will need make and model of the printer and Windows OS version (eg. XP, Vista etc.). It would also be useful to know if the computer and printer are connecting to router via LAN cable or wireless.
If possible better to connect the computer to the router using a cable for the printer installation.
Mar 03, 2010 | Office Equipment & Supplies
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Compaq Presario 2232US. The printer on the Desk Top works. From the Desktop, I have 'shared' the printer. From the Laptop, (Compaq)under Control Panel, Printers, the printer Icon is there, however, I...
hi im josh, friend you need to set up network connection for printer config.becoz it is different connection from your internet.try to do so.good luck.
Feb 16, 2009 | Computers & Internet
Do i need a wireless router in order to operate my wireless canon printer?
Hi
Its now mandatory that we need have a wireless router to connect to a wireless printer. Few wireless printer can be connected via ADHOC (ie) without a router.
Printers can work with APIPA (Automated Private IP Address)of the wiress PC.Kindly revert back for any clarification.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | Office Equipment & Supplies
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
Ricoh Aficio AP3800C Laser Printer Logo
349 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
