Question about Sunbeam 2366 MixMaster Series Hand/Stand Mixer
My sunbeam mixmaster just quit, the moter runs but the beaters do
It is almost like a gear went out
SOURCE: 2359, 2360 sunbeam mixmaster
It is the worm gears attached to the front of the motor in the housing I had the same problem on the heritage series. The parts are plastic so inevtiably they wear out.
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
SOURCE: After dough hooks for my sunbeam mixmaster model no. mx-ac
Use this link. I'd been looking for years and I found them here. http://buyitnow64.stores.yahoo.net/sustmidoho.html
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: Sunbeam Mixmaster model 9 speed control problem
OK, this may not be a solution, but might help you get there.
The speed control is NOT a potentiometer, it is a mechanical governer, and may be out of adjustment, or one of two components in the speed control mechanism has failed. The following is a test/ adjustment procedure.
During this procedure you will not be fiddling with electrical components (No risk of shock) You will be making adjustments with the motor running.
In the centre of the speed finder dial is a chrome cap. This can be *carefully* pried out. Be gentle, it's easy to chip the phenolic resin plastic.
Behind this cap is a nut around a threaded part with a screwdriver slot. Using a spanner and screwdriver to stop the centre part turning, loosen the nut some.
Turn the speed finder dial to 1. Plug the motor in and switch on. Whilst restraining the outer nut with a spanner, turn the central screw. From memory, it needs to be turned clockwise, that is, screwed inwards. The motor should respond by slowing down. Should you get no speed change, try turning the screw the other way some.
If you get a speed change, continue turning the screw in that direction until the motor stops. Now screw the other way until the motor just starts again.
This is the lowest speed and corresponds to 1 on the dial. Check the speed finder dial is still pointing to the 1 position. Lock the adjustment screw by restraining the central part, and turning the nut clockwise with the spanner until tight. Try turning the dial to see that the speed changes smoothly throughout the range. You may need to tweak the adjustment a little to get things just right.
Once you're happy with the speed control refit the chrome button, and you're done.
If you could get no speed change, one of two components under the speed finder dial has indeed failed.
Now you will need to determine just what the machine is worth to you. A motor specialist should be able to diagnose which part has failed. However, new parts will not physically fit and modifications will be needed. This could prove costly. If you know an inveterate tinkerer, you're costs could be substantially lowered.
Best of Luck.
Posted on Jul 11, 2009
  • 3 Answers
SOURCE: Sunbeam Mixmaster 12 speed may need lubrication
Part 1. Oiling the model 12:
Anyone can do this part.
On the top of the motor are four places where oil should be applied.
Starting from the speed finder dial and working forward-
There is a small hole on the top of the motor, just in front of the speed dial. Using a wooden skewer or a match, clean the hole out, and apply two drops of good quality sewing machine oil.
On top of the motor, and near and behind the juicer attaching cone is another hole, sort of key-hole shaped. Clean it out and put in one drop of oil only.
Three drops of oil go into the juicer cone. Let them run down the side of the hole.
Next to the juicer cone is another round hole. You may need to turn the handle as in removing the beaters to uncover it. Clean this hole too, and apply another three drops of oil.
Do not apply more oil than specified. It will get into the works where it shouldn't.
The following proceedures assume some mechanical ability. Read first to assess whether you are competent before starting.
After all these years, the gears in the front of the motor housing probably need fresh grease. This is a fibre based food grade grease that can be obtained from most bearing sellers. (I used a non-food grade grease, but I have to watch that the motor doesn't get too hot, and the grease run down the beaters, which can happen in extreme conditions.)
Prepare to get greasy during this proceedure. Latex gloves are an asset for doing this job.
Remove the cover plate in the centre of the front, and then the central screw from the front and pull away the front housing cover and handle. Don't loose the coil spring inside. It goes over the screw you just undid.
Unclip the return spring on the beater ejector, and remove ejector and spring together, slide the ejector down and off the beater spindles, then up and out of the guides..
There are four screws that retain the gear cover. The lower right hand one also retains a wire. Remove the screws, and gently bend the wire so the cover can be removed. There is a gasket underneath. Take care not to break it, it's brittle.
Once the cover is away, the gears and worm shaft are visible. Using a pop stick or old screw driver, remove the grease around the under side of each gear. A square headed set-screw retains each gear. When you find each screw, remove it completely. Turning the worm shaft will make the gears rotate.
Once both screws are out, pull the beater drive shafts downwards and out of the housing, and lift out the gears.
Using pop sticks, paper towels etc, but NOT solvents, clean out the gear space. Remove all the grease possible. A toothbrush is good for cleaning the worm thread. Use someone elses.
Wash the gears and shafts in petrol, kerosene or similar and dry thoroughly.
Reassembly is the above in reverse order, first filling the gear housing with fresh grease.
Grease each drive shaft lightly before refitting. Note the holes for the set screws in the shafts.
The nylon gear goes on the left, brass under the juicer cone.
Fit the nylon gear first, working the shaft upwards until the locating hole in the shaft can be seen through the screw hole in the gear. Fit and tighten the set screw.
Align the brass gear so both screws face forwards at the same time when engaged with the motor worm, to prevent the beaters clashing. You may have to put the brass gear in and out a few times to get the right teeth engaged with the worm shaft. Then slide the shaft in, once again observing the alignment of holes to ensure the set screw locks the gear securely.
Put everything else back in reverse order. Apply a smear of grease for the beater ejector where it slides, and don't forget to put the wire back under it's screw.
Part 2, speed control.
The jerky operation at low speed is probably due to dirty points in the governer. Addressing this involves disassembling the rear end of the motor.
DON'T pull the motor armature out of the housing without first removing the brushes during this proceedure. There's no need to remove the armature, but if you're curious....
Remove the chrome cap from the centre of the speed finder dial. Remove the lock nut from the thrust control screw under the cap. Remove the dial, catching the washer that goes under the nut.
There is a resistor, usually green, and a capacitor, a small aluminium cannister under the dial. Gently pry the retaining legs away from one end of each and remove them. Note which one goes where so you can put them back correctly. Marking with a felt pen is a good idea.
Now are visible two slotted screws. Remove these screws and pull the governer housing back and away from the motor. Note the pin with a plastic head, and remember to put it back when reassembling the same way around.
Locate and clean the points with a slip of soft wood and metal polish. Clean away the polish thoroughly. Do not use emery paper, it will make the points arc, and speed control will be worse than now.
Put everything back the way it came off.
To reset the governer, leave the locknut on the thrust controling screw loose. Set the speed control to position 1. Whilst pressing the dial home with one hand, screw the thrust screw in or outwards until the motor just starts to run, and lock the screw by tightening the nut. Test the control for full range, and tweak by slightly altering the thrust screw position as required. Getting the speeds just right first go is usually a fluke.
Replace the chrome cap and you're done.
Posted on Jul 18, 2009
Mixmaster junior
This is an issue you will have to take up directly with Sunbeam. Be sure to provide specific model information
Aug 04, 2013 | Food Mixers
I need the internal gear set for the Sunbeam Mixmaster Model -10. Where should I look/
Chero, unfortunately because of the age of this unit Sunbeam stopped production of the internal parts.
Apr 14, 2012 | Food Mixers
I have a new sunbeam mixmaster 2594 and can not remember where I put the user's guide. There are two different shaped mixers and I don't know which goes where.
Hello Hdjohnston! If I were you I would call Sunbeam's Customer service number
Or email them and ask for a replacement user's guide (aka manual). This shouldn't be a problem as I've gotten replacement guides for other things before with no trouble :) Better yet, here's a link to get you your manual from Sunbeam's official website:
http://www.sunbeam.com/InstructionManuals.aspx?section=
Also, if you sunbeam mixmaster is like mine, it you look at the holes where the beaters are inserted it shows little symbols of beaters (one with for example a square top and the other with a more curved top) which lets you know which type of beaters goes in where!
Hope this helps! Kat
Nov 14, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam 2366 MixMaster Series Hand/Stand Mixer Logo
165 people viewed this question
Top Sunbeam Food Mixers Experts
Oscar Netto
Oscar Netto
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
