Question about Kenmore Elite 45986 Front Load Washer
Washer sits over night with nothing in it and the next day it's full of water?
  • 20 Answers
Sounds like you may have some "sand" stuck under the water inlet valve seat which will then allow water to constantly trickle in and after a long time period you are noticing the water. Easy fix is replace water inlet valve...if more techie some valve you can take apart to get to seat area and get "sand or what ever else could be hung up in seat area out and fix your self. depends on expertise and or valve
Posted on May 22, 2009
Digitalis device does not work I fell into the water
Put it into a zip lock bag full of rice. Let it sit over night. The rice will absorb the moisture from your device. Try it the next day. Good luck!
Feb 18, 2016 | LG Cell Phones
Car overheated, let sit over night, next day put in antifreeze, car will not start
check fusible link to battery. Check battery terminals are clean and tight. .Check reason for overheating
Mar 28, 2013 | Cars & Trucks
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
After sitting for several hours water pools inside the washer. No water when a load finishes but water standing inside the next day...
Turn the watersupply off to the washer for a day, if there is no water there after a day, replace the water inlet valve/s.
If there is still water there, then it must be coming from the sink waste if the washer outlet hose is connected to it, kift the hose higher, this will prevent it from syphoning back into the washer.
Please rate my solution.
Thanks.
Nov 04, 2009 | Washing Machines
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
My washer stops after the wash cycle. not draning or spinning
CHECK THE RUBBER DRIVE BELT FOR THE PUMP UNDER THE WASHING MACHINE
May 09, 2009 | Washing Machines
How do i clean the mold off my humidifier?
Fill it to with in an inch of full, add two tablespoons of clorox and fill it the rest of the way. Run it for a few minutes and then just let it sit over night. The next day empty it out and refill it with fresh water and one teaspoon of clorox. You will be good to go.
Apr 02, 2009 | Duracraft DWM-250 2.5 Gallon Humidifier
What to do with a pone full oif coffee?
its too late to do anything youh should have took it apart and dried it out with a hair dryer let it sit over night than turned it on in the morning thats what i did when mine fell in mop water and it worked after the next day
Jan 01, 2009 | Sanyo MM-8300
Cycle never finishes.
we have an issue with one of three things
on the sides of the lid the hinges are bolted to the lid with 2 screws on each side
ferify that the secres are tight
if so then you have a lid switch that needs to be replaced or the water pressure switch in the console is bad
Apr 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Feb 18, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Kenmore Elite 45986 Front Load Washer Logo
119 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
