Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Trans dose not work since i replaced rear tire on lt 1000 tractor
It worked fine . i started it uo and backed out of shed, when i went forward it was fine but right rear tire was flat and came off rim. i changed tire and now trans dosent seem to engage. i r&r drive belt but no luck. it is craftsman lt 1000 . i think about 1999
  • 118 Answers
When you had the wheel off you probley dropped the key on the axle it should be about a quarter of inch square and about an inch long. Good Luck.
Posted on Oct 11, 2013
Similar thing happened to me . There is a half moon "key" that slides into a groove in the axle. Sounds like that fell out when you took off the wheel. Look around where you took the wheel off to see if you can find it. If not they're not very expensive at a repair shop. I did not know this & I took in in to the shop. Luckily they only charged me for the part.
Posted on May 18, 2009
  • daniel perez Jun 27, 2013
    guess what? as soon as i read your suggestion i went out to the garage and backed my car out and checked the floor.there it was just like you said, the missing key.thanks a lot you for your expertise
Is there a solution for forward and reverse selector not functioning?
Make sure the trans axle free wheel lever is in the drive position
Oct 13, 2015 | Husqvarna Garden
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Noma model signature 1340, 12.5 HP riding tractor. i am not sure of the age. last time we used it to cut grass, it worked great. we parked it in the shed. went to use again and it starts and runs...
Hi, Just got your request and am now going to look up all I can find on this model of tractor. In the mean time double check your push or drive lever again to make sure it is not binding and make sure the blades are not selected, although I am sure they are not but at this point I am not ruling anything out. I will have to dig into this issue and check on the trans axle set up for you.
Oct 22, 2011 | John Deere Garden
John deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
May 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not go forward or backward
SOME JD TRACTORS HAVE A FREE WHEEL VALVE THAT TAKES THE TRANS OUT OF GEAR SO WHILE YOUR PUSHING OR TOWING IT WILL NOT HURT THE TRANS. THERE SHOULD BE A LEVER THAT YOU PULL OR PUSH TO REINGUAGE THE TRANS
Sep 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
CRAFTMAN LT 1000 no reverse
if it has a reverse belt it could be broken or sliped off the pulley
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
245 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
