I have an LG 4600 phone from Telus, Canada. I used the User lock to lock my phone and I donot recall the lOCK CODE ON IT. iS THERE ANY WAY i CAN RESET THE lOCK CODE TO UNLOCK MY PHONE SO THT I CONTINUE USING IT?
-   Thanks to everyone who helps! My LG VX8100 is locked and I don't know the 4 digit password. Nor do I know what an imei number is. Here's what's under the battery:
S/N: 507KPYR0204954
ESN HEX : 1D959E10 VRZ
Any help will be much appreciated! Thanks.
Jeff-   Guest
Nov 29, 2007
-   hi. i'm trying to delete a phone # but i cant cause it says to input the "unlock code". the phone is a lg td6100. and i do not know what imei # is but i tried to find on back and nothing. i have tried the last four digits of my #, and the default, 0000. both does not work.
thanks
PS: these are all the #s i can find FCC ID: BEJVX6100 SN: 609KPPB0041560 ESN HEX 1538D30C-   LSProduction
if you give me the imei number from underneath your battery on back of phone looks like 123456/344/344 about 16 numbers long if you give me this i can get you master override code and this resets the security code let me know if you need this every phone has different override code and the imei number lets me et the codes for you ok
Which is the best Cell Phone having the feature of 3G in brand Nokia within price brand of...
(More)
Which is the best Cell Phone having the feature of 3G in brand Nokia within price brand of Rs.10,000. Thanks in advance, jaypoo
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer...
(More)
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer care service and then they gave it to me, when I put it in it said I had to change my Pin code, so I changed it and now I forgot it.
How do I change it again ?
Hello. I used the touch screen last night to send a text, plugged in the phone to charge it, and...
(More)
Hello. I used the touch screen last night to send a text, plugged in the phone to charge it, and this morning I unplugged the phone and the touch screen doesnt work, only the manual buttons do.
inspite of folloing format procedure n72 hangs and will not allow any function i have to remove...
(More)
inspite of folloing format procedure n72 hangs and will not allow any function i have to remove battery to restart and with 30 sec it hangs,
