Monitor malfunction--back lighting?
I have a Dell E153FPb 15" flat screen monitor.  At first, when I turned on the computer, I thought I had a completely dark screen, but after checking all the connections and on the advice of my brother, I tried shining a bright light directly on the monitor and I can just make out (with a lot of eye strain) what is there.  My brother says this means the back lighting is shot and I need to open the monitor to see what sort of light I need to replace it.  Unfortunately, I can't figure out how to open the thing, though I've unplugged it and unscrewed it from its base.  Any ideas?
  • 02oskc Dec 10, 2007
    exact same proble man, did you unscrew the stand at the hack with four really fat screvs? i have thesame problem. I have found a small holw with a padlock sign next to it, but i don't knoqw how to unlock.
  • Ken742386 Jan 11, 2009
    To open the monitor you need some flathead screwdrivers to pry the case apart after you remove the base from the back. The prying part is always scarey but you should be able to spot connection points after the first few separate. Best place to start is on top or on one of the sides and be careful, you dont want to start at the bottom for fear of damaging the controls. Do not put the screwdrivers too far in. As for the hole with the padlock signs, those are for security cables to lock equipment to a desk with. Now as for actual repair I havent quite gotten that far yet with it.
To open,remove monitor lcd side up, the silver screen frame comes off,try opening above logo,get it started and it comes right's your inverter,the thingy that your backlights plug into.
Posted on Apr 01, 2008
  • 36 Answers
Usually with this type of fault it is the cap on the inverter board gone low in value causing a small fuse (next to it) to go open circuit.
Posted on Feb 02, 2008
The padlock sign is for an anti theft device.
To open the monitor, pay-pal me $6.00 and I will email you with instructions.
Posted on Oct 31, 2008
Screen is too dark. Have trying the auto adjust, itsn't helping.
Auto adjust would retore the screen to what is usual of the Tv not the users expectations. Usimng the brigtgness contrast buttons to control a picture quality accustomed.
Jan 29, 2011 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
The Dell E153FPb monitor works, but has a very dark screen. the picture is not clear at all, but i can see a small portion of it as if a bulb may be out.
Hello Breon, hi, most likely that the LCD back light is going bad, or the inverter board is giving up, or could be loose screws, this needs to be checked and diagnose.
Sep 20, 2010 | Dell E153FP 15" LCD Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Dell bd:
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
You need to open it up and check the fuse and the transistors on the power supply/Inverter board, see pictures here:
Post back what you see so we can guide you further.
Mar 14, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Dell e152FPB LCD monitor backlight power problem
Check the four transistors (c5707/5706) in the inverter section for shorts, board looks like this?
Feb 20, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Screen is blank
Those models are made by BenQ. Their notariety is bad solder connections that cause the drive transistors to overheat. Sometimes it just blows fuse pf751(2 amp); other times it will damage a transistor or two (2sc5707 or 5706 x 4).
Be sure to resolder the output transformer leads.
Monitor Mike
Mar 16, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
My e153fpb monitor went dark
Try resetting the monitor to default settings by getting your manual out. It will guide you through the process. If that does'nt work then check for any updated drivers.
Apr 24, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Screen not working
there is a problem with the degausing coil of the monitor. just open the case and try to clean the degausing coil. thx jsut vote for me so that i can help u better.
Aug 29, 2007 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Open Questions:
Computers & Internet Logo
305 people viewed this question
David Payne
David Payne
