Question about Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Lock button is to unlock and unlock is to lock
Prestige car alarm.model number 5bcr07. when i click the lock button it unlcocks my doors instead locking them. when i click the unlock button it locks my doors when they are so post to unlock. help me please. its buggin me.
  • 33 Answers
The lock/unlock outputs from the main unit are reversed. There are two negative output wires from the unit that control the doorlocks, if you just switch them around, they will function correctly.
Posted on Jun 04, 2009
How do unlock my sentry electonic safe?
Hello, If you don't have the combination you will have to write sentry cust service with the model and serial number to get the combination. Here is their number you can call: (800) 828-1438
Jun 01, 2014 | Audiovox APS20B Prestige Programmable...
I have an after market alarm the model number on it is 118c1123 -- other than that I do not know what it is called. Sometimes the car will not unlock when pressing the remote many times. It only does...
hi
first i would change the remote control battery's
if that works i would buy compatible remotes and reprogram via that working remote for a spare
i that didnt work
i would open the car via the key remove the cover under the dash below the steering wheel
there are normally 2 fuses to a car alarm remove the fuse on the red power led that will disable the alarm
but it will also disable the remote central locking
but you will b able to unlock the door with the key a start the car
aries
Oct 16, 2013 | Prestige Replacement Alarm Antenna...
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
Prestige 2 way remote 5bcr07
That little "S" is the power save feature. Press the "F" and the lock buttons together to toggle the feature on and off. With the S on the battery in the transmitter will go into a power down mode when alarm is in disarmed state to save battery life.
Aug 02, 2009 | Gmc Dodge Ford Reverse Back-up Sensor...
Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
375 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
