Hello I get a Load Error mesage in a black screen after loading bios. Error: "Load Error! Press any key to continue" My conputer: "ACER ASPIRE 5600" Constructeur Acer, inc. Nom du produit Aspire 5600 Syst?me d?exploitation Microsoft Windows XP ?dition familiale Processeur Genuine Intel(R) CPU T2250 @ 1.73GHz Chipset Intel 955XM/945GM/PM/GMS/940GML Carte LAN sans fil Intel(R) PRO/Wireless 3945ABG Network Connection Carte Ethernet Realtek RTL8139/810x Family Fast Ethernet NIC M?moire Syst?me 1 GB M?moire vid?o 512 MB Disque Dur 1 ST9120821A,111,79 GB Lecteur CD/DVD 1 PIONEER DVD-RW DVR-K16RS Vid?o ATI Mobility Radeon X1300 Audio Realtek High Definition Audio PS: I can boot windows when I boot with "Ultimate boot CD" i can't boot normaly by the hard disk. Could you please help me to find a solution! Thy.
  • JDUFAUR Oct 16, 2007
    Information:
    1. The MBR could not be modify, only read action!
    2. I reloaded a original bios configuration also and nothing change.
    Scholar:
  • 155 Answers
The Bios should not be your problem and the MBR doesn't have anything to do if you didn't play with Windows installations or with any utility to create an image of your hard drive.
To understand where the problem is coming from:
- Ask someone to go to http://www.knoppix.org/ and download a Knoppix CD
- Create a bootable CD from the ISO downloaded
- Enter in your Laptop BIOS settings and change the first bootable device as the CD/DVD
- Insert the Knoppix CD and boot your Laptop
- Knoppix will start and ask boot:
- Just hit Enter
- When Knoppix has finished and it's running you will have a nice graphic interface
- click on the HD icon on the desktop and see if you can see your files, if not you have a bad Hard disk
- Knoppix has also a utility to test the memory too.
If you tryied to install another copy of Windows or you made an image using some software like Ghost, you have to:
- boot from a floppy disk (Download and create from here http://www.bootdisk.com/bootdisk.htm, I suggest Windows 98 SE)
- At the prompt type FDISK /MBR and press Enter
ATTENTION: If you type something different you may distroy all your files on your hard drive
Posted on Oct 19, 2007
Reformat hdd from bios
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
Feb 17, 2013 | Acer Extensa 4620 Notebook
Windows logo error mesage
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
if this fails to fix the problem
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
hope this helps
Aug 14, 2012 | Western Digital (WD3200JS) 320 GB Hard...
What keys change bios values on asus u46e
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
P4c800-e gives error bios not loaded
this motherboard is supposed to have crash free BIOS an overclocking ability and power loss restart
is it happening on boot up the drivers have not been loaded or might not be detecting a bootable device the first things to check are the leads motherboard to your hard drive make sure they are securely seated with no dust built up also the same with computer ram and cmos battery and make sure the sockets are cleanThis message is generated by computers with SCSI / RAID controllers when no bootable drive is detected on the controller. This is not an error message unless you have a bootable drive on the SCSI / RAID or you are wanting to use a SCSI or RAID drive. If you are not using a SCSI or RAID drive and your computer has onboard a SCSI or RAID controller, this message can be disabled by entering the computer CMOS Set up and disabling the onboard SCSI or RAID During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart If your computer is unable to boot or you wish to restore the BIOS back to bootable settings and your computer uses an ACER BIOS, press and hold the F10 key as you turn on the computer. While continuing to hold the F10 key, you should hear two beeps indicating that the settings have been restored. AMI BIOS Older AMI BIOS could be restored back to bootable settings by pressing and holding the Insert key as the computer is booting.
BIOS / CMOS diskettes
Early 486, 386, and 286 computers may have required a floppy disk in order to enter the BIOS setup. These diskettes are known as ICU, BBU, and SCU disks. Because these diskettes are unique to your computer manufacturer, you must obtain the diskettes from them. See the computer manufacturers list for contact information. Early IBM computers Some models of early IBM computers required that the user press and hold both mouse buttons as the computer was booting in order to enter the BIOS setup.
Other suggestions
Finally, if none of the above suggestions help get you into your CMOS setup you can cause a stuck key error, which will usually cause the CMOS setup prompt to appear and remain until you press a key to continue. To do this press and hold any key on the keyboard and do not let go (you may get several beeps as you're doing this). Keep holding the key until the computer stops booting and you're prompted with an option to enter setup or to press another key to continue booting.
hope this helps
Jul 28, 2011 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
I download bios v 1.13 from acer website and after i flash the bios, my computer cant boot to windows. How to reset acer aspire 5935g system bios to factory setting
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart Hope this helps
May 28, 2011 | Acer Computers & Internet
Iam at black screen that said F1 to resume i pressed and sendme to bios utility how can i go back to regular screen windows
What was the error-message just BEFORE that 'F1' message?
Turn the computer off, wait, and turn the computer on.
If you get into BIOS SETUP,
use the "arrow" keys (UP, DOWN, LEFT, RIGHT)
to highlight the 'Load BIOS defaults' menu-item.
Press ENTER to apply that option.
Use the arrow keys to select "Save and Exit from BIOS setup".
Press ENTER to apply.
Oct 24, 2010 | Computers & Internet
Windows will not load up white acer screen comes up then 2 beeps and white writing on black screen shows various errors
Use the windows CD if you have it.
Start the computer and enter the BIOS menu. Change the 'boot priority' or 'boot order so that the CD drive is before the HDD. Save your settings and restart the computer.
Enter the windows CD and press a key when prompted to load from the CD. Windows has a series of utilities that may (or may not) assist you in sorting the various error messages that appear on your computer when booting.
I hope this solves your problem : - )
Sep 30, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer Load Error
Detect the Harddisk in the BIOS setup & if it is detected then also it displays in the same manner then do one thing replace the BIOS.
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
137 people viewed this question
Alun Cox
David Payne
David Payne
