Canon BJC1000 Bubble Jet printer suddenly quit during a print out. Checked out all obvious causes. Power OK, connection to PC OK. What can I do next ?
  • 2 more comments
  • george_gille May 17, 2009
    Hi Rylee
    I unplugged the power supply, took out the cartridge and then reset it in place. Upon plugging power supply back in the cartridge moved to the centre and then cycled twice before returning to the far right position. The printer will not print on command from the PC.
    George.
    Cannot find my printer driver. Downloaded the Canon driver detective from the site you sent but cannot open as "This program has performed an illegal operation" I guess my AVG virus protection has found something.
  • george_gille May 18, 2009
    Thanks Rylee
    I have downloaded the Canon BJC 1000 Driver and saved it to a folder, but I cannot get it to install on my computer. I am using Windows 98 SE on a regular PC. Please advise
    Thanks George.
  • george_gille May 19, 2009
    Many thanks Rylee,Printer now prints successfully and I have th driver on file for future use.
    George
    Brigadier General:
  • 8,619 Answers
Hi
Please check if the ink cartridges move when you give a print command. If the BJ cartridge will not return to the home position (stays in the center) or will not move away from the home position (stays to the right), then the BJ cartridge may need to be reseated or replaced.
Reset the power to the printer either with the power button or by unplugging the power cord. Release the locking lever that locks the cartridge into place. Carefully remove and inspect the BJ cartridge. Place the BJ cartridge back in the printer and lock the locking lever completely. Reset the power to the printer again, either with the power button or by unplugging the power cord.
If the cartridge will not move after attempting the above steps, you may need to replace the BJ cartridge. Also check if the ink cartridges are empty. Please check if you are getting any error code.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 16, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith May 17, 2009
    Hi
    Please reload your printer drivers as it should work after this. Also check the cable and clean if corroded, and replace anything if needed.
    Thanks
    Rylee
  • Rylee Smith
    Hi!
    Please turn off the computer and printer for fifteen minutes. And after that first start the computer and then printer. After starting the printer please try to print a test page on its properties. If still the problem persists please download the drivers again on this link---
    Printer Canon BJC1000 Drivers
    After downloading the drivers again check printing test page. You may also refer to this link for further reference---
    Canon Drivers Download and Information
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith May 18, 2009
    Hi George
    You need to open that folder and in that folder their will be a run.exe file which should install the software on the computer.
    Thanks
    Rylee
Cannon MP600 printer shut itself down during printing operation . Pressing ON/OFF button will not turn it. I checked connections and power source. Still, no reaction.
Re: "Cannon MP600 printer shut itself down during printing operation ."
If a Canon inkjet printer is turning itself off, then problem is either control board or power unit. When this happens printer is often considered beyond repair, and in any case it must be tested by a technician to find out the problem.Repair involves testing volts out from power unit and testing components on main board.
Considering that the MP600 is quite an expensive inkjet, I suggest contacting Canon support and asking a quote on repair.
Here Canon support pages:
Canon U.S.A. : Contact Us
Canon U.S.A. : Support
Canon UK - Support
Canon South Africa - Support
Aug 30, 2010 | Canon Office Equipment & Supplies
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
Cannon bubble jet 5100 cant connect
What are you trying to connect to, you computer?
you are trying to install drivers?
have a look here for the drivers
http://software.canon-europe.com/products/0000410.asp
select Windows 2000, if running Windows XP
Jul 19, 2009 | Canon BJC 5100 InkJet Printer
Canon bjc1000 will not print
check your drivers and try again, check the cable and clean if corroded, and replace anything if needed. try reinstall your pc to whatever your system is.
Jan 10, 2009 | Canon BJC1000/CanoScan FB320 InkJet...
HAVING TROUBLE PRINTING
Make sure that you have the printer software installed and check to make sure your printer is set as your default which means it will send whatever you are trying to print to the printer you have set as your default.
Oct 19, 2008 | E-Machines eMachines Desktop PC
It will not print. The power button is blinking on my Cannon Bubble Jet printe.
Unplug your printer, clear/delete your print job. Shut down your pc. Boot your printer, restart your pc. Have you tried this?
Aug 14, 2008 | Canon Office Equipment & Supplies
80 people viewed this question
k24674
jasbo
jasbo
