Question about Kenmore 24032\24036 Top Load Washer
Washer leaving alot of lint on clothes
I have a Kenmore Model #110.81661100 Top load Washer and it seems to leave alot of lint on the clothes no matter what I do. I don't know if this washer has a filter of some sort that might need to be replaced (I could not find where that might be). Anyway, could you help me with this? Thank you.I have the same lint problem. My washer is a Kenmore 110.82870120. I can figure out how to remove the agitator cap, in order to follow your instructions. Is there a release switch somewhere? I'm assuming the agitator cap is the cylindrical piece at the top of the agitator. Thank you!
    Brigadier General:
  • 3,614 Answers
The detergent amounts given on the usage label of the detergent box are for average water hardness (4-9 gpg). If your water is harder than average, or if your clothes are really dirty, you’ll need to use slightly more detergent than what’s recommended on the box. If you have really hard water, you may need to add a packaged water conditioner to each load,
If your water is softer than normal, you’ll create too many suds, which will retain gookus. In this case, you’d use slightly less detergent than recommended on the box.
Let me know for further clarifications
Posted on May 16, 2009
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Leaving lint all over my clothes
Check your lint filter and your dryer duct that goes out back of dryer to outside . Might have partial clog
Jan 19, 2013 | Kenmore 22642 Top Load Washer
Kenmore eilite washer
Please try and reduce the time for the dryer as it could be due to excess drying or higher RPM.
Jun 26, 2012 | Kenmore Washing Machines
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Dec 26, 2010 | Kenmore 22642 Top Load Washer
My calypso machine leave alot of lint on clothing
you have to clean the lint trap before every use. I assume that you know that. also , you need to clean the area where the lint trap is really good, so you dont have a dryer fire.
Aug 25, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
THE ONLY FILTERS YOUR WASHER HAS ARE LOCATED UNDERNEATH THE AGITATOR. REMOVE THE AGITATOR CAP AND TAKE OUT THE 7/16 BOLT DOWN IN THERE AND PULL THE WHOLE AGITATOR OUT. IN THE TUB YOU'LL SEE FOUR FILTERS AROUND THE AGITATOR SHAFT ASSEMBLY THOSE ARE THE ONLY FILTERS YOUR WASHER HAS. OTHER THAN THAT IT IS NOT THE WASHER CAUSING THIS PROBLEM. WHEN YOU WASH CLOTHES IF YOU CANNOT SEE THEM GOING DOWN IN THE TUB BY THE AGITATOR AND OTHERS COMING BACK UP ALONG THE OUTTER EDGE THEN YOU ARE OVERLOADING THE WASHER. HOPE THIS HELPS YOU.
Apr 13, 2009 | Washing Machines
My stakable maytag washer leaves lint marks on the
new washer have what is called a washer drain protector, in other words it's a lint catcher for washers and your model has no such part. Do you use powder or liquid detergent? It seems to me that what you see is residue from too much detergent if you use powder. I've heard others with this complaint and to no avail can figure out the cause of this, at least from a view point of a simple wash.
Mar 16, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore elite calypso washer leaves clumps of lint on clothes
sorry to hear you got one of these. they stopped making that model because of multiple problems. I have seen the lint issue come up with these over and over w/o a solution. I can say if you are not using a dryer to dry getting one will help.
Feb 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 92274100 washer leaves lint on everything
Be sure to use higher water level on machine, don't overload machine Seperate lint givers from lint attractors. There is a lint catcher mounted on the bottom of the spin basket but it is self cleaning.
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
