Question about Jura Capresso Impressa F9 Espresso Machine
The cleaning cycle is not complete (Jura F9)
After inserting the cleaning tablet the machine is supposed to ask me twice to empty tray, My machine does not ask me to do it even once, but stops the cleaning cylcle and asks me to press maintenancea, clean the tray and then it says select product.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
This indicates that the Flowmeter is either dirty or defective, it sends incorrect messages back to the electroninc board about the waterflow. It`s located on the left side (seen from behind) as a white sircular box with 2 hoses and an electrical contact on top of the lid.
Posted on Jul 07, 2009
My machine hasn't requested a clean cycle in quite a while. Is there any way to start the clean cycle manually?
At the time of set up, Jura instructions ask activating the use of Filter cartridges. This eliminates reminders for descaling.
Solution:
Throw away the filter cartridges that are expensive, ineffective & block descaling reminders.
Descale the machine every three months using manual descaling method. See link for instructions. Services Unlimited Inc Parts Guru Since 1988
Jun 20, 2016 | Jura Capresso Impressa F9 Espresso Machine
Empty Tray
@Derekns74 How do you remove the switch? My C3000 also reads "EMPTY TRAY" constantly, even if the tray is empty and clean. It does not display the "EMPTY GROUNDS" error only "EMPTY TRAY"
If I remove the tray it display "TRAY MISSING" but whenever I insert the tray again, it reads "EMPTY TRAY"
On one occasion when our power went out, it fixed the machine, so that it stopped reading "EMPTY TRAY," but after a day or two it stopped working and displayed the same EMPTY TRAY error message again.
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
The "clean machine" edit will
How are you doing the clean cycle ?
You should put a tablet in the coffee grounds front lid.
Push the clean button on the inside front panel.
The machine will ask you to open tap and empty tray along the way.
Make sure it does the full cycle.
Jan 30, 2011 | Jura Capresso Impressa S9 Coffee...
Hello, I have purchased Jura Impressa F9 about 4 years ago and have been using it a couple times daily since that time. Some time ago, I have started having problems with brewing coffee on each program....
machine is most likely clogged with old coffee grounds and needs a good cleaning cycle malf 8 is problem with the stoke of the piston can not make a complete cycle thur get your book out for machine and read list for cleaning machine follow remove power cord for a few mins. let machine cool down if hot from prior use then plug back in power up and do cleanning cycle with tablet follow book worst case would be oring seals on piston are no good or very dry making machine work to hard to move piston in this case service is needed good luck steve
Sep 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Tray will not insert properly, a flap seems to be lowered
Start up the machine, take insert everything but the used grounds container. The machine will reposition the brew unit. When the machine says "heating", take out the tray and now you can insert everthing with the used grounds container. You can of course run a Rinse cycle if the machine doesn`t start positioning right away.
Aug 30, 2009 | Jura Capresso Impressa F9 Espresso Machine
Impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Mar 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Missing tray error
Insert the tray-all of it except the grounds container.  The message disappears and you can wait until the machine continues it's cycle and then asks to empty the tray.  Empty the tray and place the grounds container back inside.  Whew, I've done this a few times over the years when I am rushing but it fixes it every time.
Jan 24, 2008 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso Impressa F9 Espresso Machine Logo
357 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
