Question about Gateway XHD3000 LCD TV
Flickering screen (likea strobe light)
My gateway xhd3000 monitor suddenly began flickering badly (like a strobe light) yesterday during use. I've tried disconnecting everything but the power cord and it still flickers when the onscreen menu appears. I've tried disconnecting and reconnecting the power cord, disconnecting the power supply and moving it to another power outlet with no resolution. Thanks in advance for your help. :)
    Novelist:
  • 159 Answers
Problem with flickering is in the board that is mounted to the back of the lcd screen. Part is only available in China.
Board will either need replacing or repairing (if it is repairable? Not all are)
I repair lcd monitors on ebay and just repaired one of these boards.
ebay id: bammbammfran
Posted on Mar 07, 2010
  • 25 Answers
Lcdpayless.com has the equivalent power adapter
AD/DC power adapter + power cord for Gateway XHD3000 30" Widescreen HD LCD Monitor . link as below:
http://lcdpayless.com/productpage.php?productId=5831
it work good.
Posted on Sep 14, 2009
  • 3 Answers
I was able to fix this by unplugging everything, including power, then press power button for 1 minute continously. Then plug power back in and see if it reappears in product tour. Repeat as necessary. Seems to unload the static.
Now several months later the problem appeared again, and this time even that wont help. I suspect that the XHD 3000 is a lemon. Bad product.
Posted on Sep 02, 2009
    Problem Solver:
  • 5 Answers
One check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
Posted on Sep 01, 2009
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
Gateway XHD3000 Monitor
I may be able to fix it for you
I believe the problem is in the same board that causing the strobing screen problem.
Cost is 150 to repair the problem board if it isfixable. No charge if not fixable.
You will have to pay round trip shipping for the monitor and power supply to Pennsylvania.
Ebays bammbammfran
Dec 29, 2009 | Gateway XHD3000 LCD TV
Upper half of screen is flickering. Started last night. Appears to heat up and flicker. When I shut the TV down and let it cool off, flicker stops, but then starts again after the TV is on for a while. ...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 16, 2009 | Gateway XHD3000 LCD TV
Flickering blue sceen
If it's a Gateway XHD3000, I may be able to fix it for you
I believe the problem is in the same board that causing the full strobing screen problem.
Cost is 150 to repair the problem board if it is fixable. No charge if not fixable.
Ebays bammbammfran
Oct 04, 2009 | Gateway XHD3000 LCD TV
Screen flickers like a strobe whenever I turn it on. I bought this screen about a year ago and never had any problems--until now. Doesn't matter what input the screen is on. It's not a power issue--I've...
Sep 01, 2009 | Gateway XHD3000 LCD TV
Strobe-like flickering in upper half of Dell monitor
The problem is the inverter on your dell monitor this is very comon.
Jun 15, 2009 | Gateway XHD3000 LCD TV
Gateway XHD3000 LCD TV Logo
2,106 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
