30 Other Users Have The Same Problem - Continued
Comment by adi_sbi02, posted on Dec 23, 2008
I cant install acer e-recovery !!!!
please help me !!!!
how to install it !!!
Comment by tmetzger, posted on Dec 20, 2008
Soma for my aspire one
Comment by Guest, posted on Dec 12, 2008
,mn,mn,mn klkj l lkj;ljk kl
Comment by pavier12, posted on Oct 19, 2008
hi there i have got the same problem i have got an acer aspire 5520 and i have deleted the partion that had the D2D eRecovery system on it i did make a backup of this vista premium system when i first got my laptop so i was wondering if anyone can help me out in making an partion on my hardrive so that i can setup the D2D eRecovery again so i can just press ALT F10 again thank you for your time on this matter cheers
Comment by nosman, posted on Sep 12, 2008
i tried 2 install acer erecovery but my computer says "Not D2D system, erecovery cannot be installed" whats that about and wat do i do?
Comment by hymapyaar302, posted on Aug 24, 2008
same problem{
Aspire 5611 AWLMI Intel core duo Processor t2050
}..cant access d2d recovery or dont have any recovery cd..i format and instal the c drive keeping d and hidden drive there itself...still alt f10 is not working on boot......what should i do..pllsss help..
Comment by Guest, posted on Jul 30, 2008
i have exactely the same problem as the guy who posted this thread
Comment by john769, posted on Jul 26, 2008
pre-installed driver making it impossible to boot windows all I get is various blue screens, I have the choice when starting up of repairing my pc which I choose, but it fails to repair and the only option is advanced options I then select command prompt as all the others are useless as I have'nt made any backup disks, but I do not know any prompts that can help. selecting booting windows normally is blocked with a blue screen.
I tried F8 safe mode and all the others which results in a blue screen after a few minutes, I have entered Alt + F10 for erecovery but cant for the life of me remember the password the hint seems totally obscure.
any help would be trully grateful.
john.
Comment by Guest, posted on Jul 20, 2008
[ NOEXECUTE=OPTIN ]
Comment by Guest, posted on Jun 13, 2008
"not D2D system, eRecovery cannot be installed" please solve my problem for acer aspire 5720G
Comment by Panag, posted on Mar 04, 2008
Hi. I recently bought an acer aspire 5720g that came with vista home premium. I repartitioned my hard drive and deleted the pqservice (hidden) partition. After that i installed vista ultimate and then I tried to install acer erecovery but i got the following message: "not d2d system, erecovery cannot be istalled". D2D recovery is enabled in bios and i haven't any recovery disks. Acer support site says that erecovery needs a specific partitioning structure to work, so i thought that creating a partition with the same size as the pqservice partition (around 10 GB in my model) at the beggining of the hard drive erecovery could work. So i use acronis disk director to do that but i have the same result. Please tell me if there is a way to install erecovery. Thank you in advance!
Comment by Guest, posted on Jan 22, 2008
the " install eRecovery Solution " hangs at 16/17. Or if I do a restart it hangs at 1/2.
But this recover to factory default i try to do on a aspire 5053 wxmi( aspire 5050)
Comment by tarark, posted on Jan 02, 2008
I have the acer aspire 5610z and i tried to restore to factory defaults then did not work, then i tried to use the acer recovery disc, then acer said i need to download thier iso file and burn it to a disc before recover, how exactly step by step do i do that, i have tried over and over but i must be doing something wrong because it still doesnt work
Comment by Guest, posted on Dec 22, 2007
my problem is the exact problem as that stated above
D2D recovery option
Comment by tarark, posted on Dec 16, 2007
Restored to factory default with computer and it could not get past step 11 of 12 and then i started all over with the disk recoverys that i burned when i bought the computer but maybe something is missing on them because it did not get past the same step after i tried it again, maybe i was supposed to do something else, is there a disk so i can use my computer again because the screen just stays in the middle saying install step 11 of 12 erecovery solution, thanks for any help
Comment by melarancio, posted on Dec 16, 2007
I forgot to mention - Windows wiped out all my system drivers too. While the reinstall of Vista now recognizes the camera it can't install it and the keyboard driver is for a Microsoft 102 key, which this isn't.
I used PARTEDIT32 to view the partitions. I know the "hidden" partition has not been overwritten. I just don't know how to get the original system back which is what I want.
I reinstalled Windows Vista and it wiped out acces to all my Acer EManagement software. I ordered Recovery CDs from Acer but don't know what to do with them since I can't access Acer eRecovery.
I tried GodSpeed's solution - I get this at f10
Edit windows boot options for: Microwoft Windows Vista
Path:\Windows\system32\winload.exe
Partition: 2
Hard Disk: 6b6b42bb4
[/NOEXECUTE=OPTIN]
Partition 1 is where the hidden files are - can I edit the previous info? I'm using a 5610Z that came with Vista Premium
Comment by Torago, posted on Dec 15, 2007
Hi
I have problem to press alt+F10 during boot up screen
doesn't work.
acer Travelmate 3210
please help me
Thinke you
Comment by chris1984, posted on Dec 10, 2007
i have acer aspire 5600 .when i install the erecovery at the begining its sais this ''not D2D system, eRecovery cannot be installed''
i enabled the d2d system on the bios but still have this problem.my hard disc is fat32, i dont know if this its a reason .pls tell me what to do.thnx
hi.i have acer aspire 5600 .when i install the erecovery at the begining its sais this ''not D2D system, eRecovery cannot be installed''
Comment by Guest, posted on Dec 10, 2007
Comment by Guest, posted on Nov 30, 2007
Hi.i have acer aspire 5600 and i cant update the eRecovery_ManagementV2.0.2021 because its show me a message like'' not D2D system restore. pls tell me what to do .thnx
Comment by Guest, posted on Nov 27, 2007
i deleted my hidden partition. now how could i make it to factory default
Comment by Guest, posted on Nov 05, 2007
Hi! I have an acer aspire notebook model 5610Z which I bought this past may of 2007, now I´m having problems with being able to repair and recover my operating system on it, when I turn it on it makes a clicking sound have checked to make sure there´s not a CD in the CD drive and there is no way I can even access my desktop to be able to run the e-recovery program. How can I repair this problem? Your help is greatly appreciated!
