Dometic RV A/c compressor runs every 10 minutes
I have a new RV with a Dometic A/C and wall mount Tstat. It appears that the compressor starts every 10 minutes. The fan does not come on and this happens even when a/c is set to off.
  • 1 more comment
  • sstgermain May 16, 2009
    When A/c thermostat is set to cool the fan wil come on and the unit works fine. The fan is not bad.
    Thermostat is turned off. Thermostat is not calling for cold air. Sitting on couch I hear compressor only come on for 5 or 6 minutes when unit is NOT calling for cooling. It will then shut itself off. When I turn on A/C and ask for cold air by setting thermostat down it will come on and run normal, fan comes on then compressor comes on voila cold air.
  • sstgermain May 17, 2009
    I think itis the controller in the A/C unit itself as I discnect the Tstatand it still does it.This Dometic has a controller box in he A/C unit itself.
  • 3,267 Answers
Looks like the fan is jammed or a coil has burnt out, resulting in heat which when detected by the thermostat, passes the compressor to star, but since the fan isn't working it manages to drop the temp near the sensor causing the compressor to shut down & restart quickly. Get the fan repaired/replaced at the earliest & don't use the m/c till then....sodeep
Posted on May 16, 2009
  • 1 more comment
  • Sudeep Chatterjee
    Sudeep Chatterjee May 16, 2009
    Firstly is the temp setting of the thermostat near the outside ambient temperature ? Thermostat setting if not solid state then chances are that it needs recalliberation, for eg, it is suppossed to switch on the fan & compressor at the same time with the compressor having maybe a 10 sec gap. This means it has to activate 2 circuits at one instance. Somehow at warmer temperature, it is switching on the compressor only and not the fan. This can happen on bimetallic strip type thermostat and solid state too if there is carbon deposit on the contact points. So the thermostat is causing this problem...sodeep
  • Sudeep Chatterjee
    This is a clear indication that the thermostat is not responding or behaving as it should. All symptoms are indication of the thermostat malfunction because its not releasing the right commands at warmer condition but functioning when set to cold. The relays(circuits) are not getting activated at the right time. The compressor is still ok because a built-in safety feature breaks the compressor circuit to prevent damage to it(due to overheating). I feel you are lucky to have the compressor still functional, only replacing the thermostat should solve it...............sodeep
  • Sudeep Chatterjee
    Sudeep Chatterjee May 17, 2009
    From your observations I agree that since you are at the site and with the freedom to experiment on the A/C, that your conclusion is perfectly logical that if even without the thermostat the behavior does not change therefore even if the thermostat is passing on the command to the a/c controls are not responding. Thus its seems to operate on a cycle of its own and not from the thermostat, as it should do in normal conditions. However yu will need to confirm that signal/command is indeed coming from the thermostat but is not being fecogonized or that the thermostats signals have malfunctioned i.e the eltronic circuitry which issues those commands after interpreting the data coming from its sensor. If you can get hold of a similar thermostat from a friend or borrow one you can then make your final desicion. And if its the thermostat only then replacing it would be most cost effective.........sodeep
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
MY dometic AC with anolog tstat will operate fan but does not cool...does not sound like compressor is kicking on ..can anyone give me a troubleshooting sequence on what to do step by step
Hi, just a few thoughts that may help, depending on your level of expertise, I suggest checking the start and run capacitors for the compressor. Then check the coil of the start relay, (usually on the side of the compressor). Can you hear whether the start relay is clicking on. Does the compressor hum or is it dead. Check for continuity between thermostat and compressor start relay
Feb 24, 2011 | Dometic Rooftop RV Air Conditioner
Air conditioner runs for several minutes then
Take it back to the dealer and have them fix it, could be a compressor froze up or a fan froze up. If you disconnect the compressor and turn it on and it trips the breaker the fan is probably
bad. If you disconnect the Fan and turn it on and it trips the breaker
it is you compressor.
Jul 16, 2010 | Dometic Rooftop RV Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Have Duo Therm roof mount A/C. Fan runs but when compressor tries to come on it just has a hum sound for about 10 seconds then after a short period of time it tries again but will not kick on
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Feb 25, 2009 | Dometic Rooftop RV Air Conditioner
Compressor tries to start but want
hi,
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Aug 21, 2008 | Dometic Rooftop RV Air Conditioner
Dometic ac in RV
Do you have a wall mount thermostat? Thats what I would look towards first since its easy to get to. Don't let your compressor run with out the fan you can burn it up. I would just use the breaker as an on off switch intill you can get it looked at.
Jul 25, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
