Question about Kirby Ultimate G Bagged Upright Vacuum
The belt burnt out and it seems as though the red arrown does not release the belt. Like it is backwards from the green arrow. It had a burning smell and the belt broke. Then the second belt started to burn out when the brush roller wasn't spinning. Not sure what might be wrong. Green light will not come on either.
  • 10,865 Answers
It sounds as if there may be a piece of the broken belt in there. Look carefully with a flash light and remove any remnants you find, using a pair of pliers if you have to.
Also, remove the entire brush roller assembly and clean it up, once again looking for any debris that may cause an obstruction. If you can't clear the problem I recommend taking it to a vacuum repair as this is too expensive a vacuum not to. Good luck and write back and let me know if you have any questions. I have worked on a number of kirby's so I may be able to assist you further.
Posted on May 16, 2009
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
I have a kirby sentria. vacuumed up my son's headphones and immediately shut if off. took brush off, unwound headphones, put it back together. when i turned it back on, the belt snapped. so i went to...
Take the front off the vacuum and check inside both the front portion and the canister for additonal clogs. Sometimes something will get caught in the impellor, causing the motor to overheat. Since there's little suction and the smell, I'd guess this is what happened.
Jan 30, 2011 | Kirby Generation 3 Bagged Upright Vacuum
I bought this second hand, so have no manual for parts, etc. I smelled something really bad, am assuming it was the belt. How do i release the head of the vaccume to get to the roller. It needs cleaned...
rotate the front belt lifter from green to red then rotate the locking knob above the nozzle. and the head will lift off. it helps if you put the height adjustment in the highest setting. did it smell like rubber burning?
Jan 01, 2010 | Kirby G5 Bagged Upright Vacuum
How to change g5 belt
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt.
You can get a replacement belt here:
Kirby G5 Replacement Belt
Nov 02, 2009 | Kirby G5 Bagged Upright Vacuum
How do I change the belt on my Kirby sweeper?
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate and you can access the belt.
Kirby Ultimate G Replacement Belt
Oct 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I want to kill my kirby
Follow these instructions step by step and it should help with the problem...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Jun 20, 2009 | Kirby G4 Bagged Upright Vacuum
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage.
7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place.
8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Roller Brush
Try a new belt. The ends of the brushroller are different sizes, so you can't put it in backwards. There are numbers and notches on the ends of the brushroll. These notches/numbers need to match on both sides when installing it. (probably need both ONES face up). Make sure that the beltlifter arrows are green on green before you install the brushroller. Once you get the brush in and the baseplate back on, turn arrows to red on red to lift the belt up before reattaching the nozzle to the Kirby. I have included a link to help with other potential problems. If you want a manual, or need any more help, contact me through the links on my guide page.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Marci
Oct 19, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
99 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
