Question about Kenmore 98702 Stacked Washer/Dryer
Spin cycle not working
Hi i have a unit where the washer will not spin and there is a rubber burning odor? is this a belt problem or something??
  • skoggie May 16, 2009
    I have the same problem. I replaced the belt but it still won't spin. Help.
    Problem Solver:
  • 4 Answers
Would say it is the belt.
Posted on May 28, 2009
  • haaland35 May 28, 2009
    would say it is the belt.
LG WM4070H front load direct drive washing machine occasionally emitting burning rubber smell.
Sanitary cycle uses calrod heating element inside of washer to heat water. I suspect that is where smell is coming from. If you infrequently use sanitary, and if you use fabric softener and/or liquid detergent, then a built up on the calrod unit can happen. When used, the buildup can produce odors as you describe.
Apr 09, 2017 | LG Washing Machines
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Performa washing machine not spinning
you will most probably find that the inside of the belt that runs on the pulley has been breaking away bit by bit and if the pulley stops where there is a bit missing it may not turn when the pulley starts to turn.
Just a thought as it has happened to me a few times
The odor is most probably burning rubber as the pulley spins on the belt
May 26, 2009 | Maytag Performa PAV2200
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Sep 11, 2007 | Maytag SAV5710 Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
167 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
