Question about E-Machines W3052 PC Desktop
Emachines W3052 Gets stuck on logo screen when starting up.
Hello, i have a few problems with my emachines W3052. When starting up it gets stuck at the emachine logo and frezzes. I can't access the BOIS (f2/DEL - f10 thing). I have some very importain information on it that contains my finals that are due monday. I really need to fix this problem. please help.
    Problem Solver:
  • 7 Answers
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
Posted on May 16, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Cant get to boot screen to start recovery on e525. I tried every f key! Only get e logo screen which will flash to a black screen with blinking cursor at top left then flashes to all black screen back to...
Some of the emachines coming with Recovery image. You need to press F11 key on starting to check whether the image is available or not. If it is there proceed with restore.
Otherwise you need a recovery CD to do this. If you don't have any CD then you could purchase the recovery disk for your emachines from the link below by entering the serial number on your computer:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Apr 02, 2012 | Acer Computers & Internet
Emachines t1116
Usually e-machine and other pc's have a factory restore setting set up in case of an error. You can; according to emachine tap the "Alt" and "F10" keys at the same time when the eMachines logo appears. Press "Enter" and follow the directions on the screen to recover the operating system back to factory condition. I hope that helps, if those keys don't work try F11 at the emachine logo. Good luck.
Nov 17, 2011 | E-Machines eMachines Desktop PC
I NEEDE DRIVERS FOR ME EMACHINES W3052 ETHERNET realtek 8201 l
Follow this link and download the "Other Drivers for Motherboard Package"
The Ethernet Driver should be on there.
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1440
Apr 30, 2011 | E-Machines W3052 PC Desktop
How do i access recovery mode on eMachines W3052
Not sure that this is what you need, but should work. If you have Windows OS, try pressing F8 when booting. A menu will be given on the screen. Will have to choose SAFE MODE and when windows loads go to START MENU-PROGRAMS-ACCESSORIES-SYSTEM TOOLS and choose SYSTEM RESTORE
Jul 28, 2010 | E-Machines W3052 PC Desktop
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
Emachine 750 loads Windows XP, shows emachine picture and locks
try this reinstall ur windows from ur emachine recovery cd and this should help let me know if it does
Dec 04, 2008 | E-Machines eMachines Desktop PC
Computer keeps crashing
it is the mother board you will have to goto emachines website and order new one i had same problem in a few days it will get worse
Nov 19, 2008 | E-Machines eMachines Desktop PC
E-Machines W3052 PC Desktop Logo
780 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
