Question about Focusrite Saffire LE Sound Card
Why does my volume control make clicking sounds when i adjust the volume knob?I use a imac
How do i un-install my saffire on my i mac(remove all files).. is this sound card compatible with i mac,it seems to make a crackling sound when i adjust the volume? thank you
  • 91 Answers
Make sure your speakers are correctly connected to your computer.
On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a USB cable, it will plug into any USB port on your computer.
• If the music in your library skips or the audio breaks up when you play it in Windows Media Player, there might be a problem with the audio driver installed on your computer. Typically, this type of problem only occurs toward the end of songs (in the last 20 seconds or so).
In some cases, you can work around the problem by disabling optional speaker effects that are collectively known as enhancements. If disabling speaker effects solves the problem, you might need to update your audio driver.
Posted on May 18, 2009
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
Hi I have just attempted a number of times installing saffire pro 14 on my pc with windows xp sp3. I inserted the saffire resource cd first to launch mix control and it keeps telling me that windows does...
In control panel audio set saffire as default.Also check that in audio properties you have speakers or headphones or whatever you using checked off.
If this doesnt work,uninstall your realtek program and drivers then reboot,this should force your saffire card to take over.
Last.. you may need to go into the bios and disable onboard sound,as a matter a fact do this first. the old soundblaster cards had the same issues.
Mar 24, 2011 | Focusrite Saffire Pro Sound Card
Change the volym
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 01, 2011 | JBL CREATURE II Computer Speakers
Hi, Have Logitech USB Handheld Mic for PC/MAC. m/n E-UR20 MAC recognized it but there isn't any sound. Thank you!
Probably need to enable it in control panel
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 20, 2011 | Logitech (980240-0403) Microphone
I installed my interface, but my recording software still isn't picking up sound from my mic
You may need to enable the microphone in control panel - see below
You will also need to check the correct sound source is selected in your recording program.
Click VOICE
That should be it.
Feb 18, 2011 | AKG Perception 220 Professional Microphone
My Saffire Le doesn't show up in AUDIO DEVICES but all is instaled corect and in my device manager I can that fire wire and Saffire are ok please try to help... it began after I reinstaled windows (now...
Go to Volume Controls - Options menu - Properties... is it in the Mixer drop down box there? You might find the problem is that any onboard soundcards you have on the motherboard are now set to default since you reinstalled. In which case go to device manager and disable it. If problem persists try a reinstall of saffire whilst the onboard card is disabled. Some motherboards allow you to disable the onboard sound from the bios menu too, that could be something to try
Oct 31, 2009 | Focusrite Saffire LE Sound Card
IMac keyboard volume control keys
Do the volume keys still work when you are booted in to OS X?
Also, try reinstalling the Bootcamp drivers that will appear when you insert an OS X disk when it's booted in to Windows.
Mar 16, 2009 | Apple iMac G4 20" Mac Desktop
Firewire audio problem
Hey Waterleo
I am running a very similar system. Black macbook and saffire not LE.
So this could be your problem. When you first connect the firewire cable to your mac from the saff you will see on the inputs a signal coming from nowhere. This is the mac syncing with the saff. Im pretty sure its the same with the LE but you must wait until your Line Mode(pad) lights turn green this means the two are connected. Try waiting for this it may take upto 3 or 4 mins sometimes depending if you are using the external powersupply or not.
If you have already done this and still nothing try this. FIrst plug a guitar into an input of the saff and confirm there is a signal being produced. If so your problem may be in your system prefs.
Apple menu --> System prefs----> sound
you will see a window with 3 tabs labled input, output and sound effects.
go to input and confirm that the saffire is in the below list and highlighted, the same for output.
Ignore sound effects.
Also i just looked at my saffire and i am not being rude now but i am assuming that your new to this tech. so there is a pot(knob) on the front for your saffire labled monitor, this is your main volume for the system.
hope this helps my friend.
Mar 07, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Focusrite Saffire LE Sound Card Logo
242 people viewed this question
Top Focusrite Computers & Internet Experts
David Payne
David Payne
Are you a Focusrite Computer and Internet Expert? Answer questions, earn points and help others
