My walls and tv screen gets a black film on it. Could it be coming from the furnace. Just cleaned my bathroom tile above furnace vent and the wall had a black film on it.
I would be concerned that exhaust is not venting properly and the soot is getting into the fresh air side of heater. Have unit checked for carbon monoxide presence in fresh air ducting. Heaters use a heat exchanger the is heated by the furnace and fresh air is blown through yje exchanger to be warmed before it gets out the vents. If the exchanger is damage or rusted through the good and bad ai can exchange creating a serious/ life threatening condition. I recommend professional inspect and repair and have a carbon monoxide detector in place and functioning. Be safe and good luck
Our timer on the heating keeps cutting out for no reason. It is like the electricity supply is cut....
(More)
Our timer on the heating keeps cutting out for no reason. It is like the electricity supply is cut. To get it back on I haev to turn it off and on at the wall. Still keeps cutting out though. Also it turns the boiler on at different times to that set. Do I need to get a new timer ?
I need to convert a ProCom Natural Gas heater (model MN200TBA) to Propane Gas. I have not found a...
(More)
I need to convert a ProCom Natural Gas heater (model MN200TBA) to Propane Gas. I have not found a website nor an (800) number for Pro-Com. Does anyone know if this conversion is possible and how? Thnaks!
Hi, I have a Clarke XR75 paraffin space heater which doesn't start consistently. Once it's going...
(More)
Hi, I have a Clarke XR75 paraffin space heater which doesn't start consistently. Once it's going it's fine, but most times it doesn't start. If I remove the cover the fan seem to be very stiff to turn. Is this likely to be the fault or is there something else I should look at? Nothing else obviously wrong. Thank, Nick
