Question about Sony Playstation 3 (PS3) Console
Playstation 3 display is in black and white
I have just bought my PS3. I have made sure the system is up to date (1.95).
When I connect it to my standard analogue TV via the Euro-Scart cable provided the display is entirely without colour.
Please can someone help :)
Thank you
  • Thirdofherne Oct 28, 2007
    I discovered this, yes it worked thank you very much. Full reset. I think it was because I'd plugged it into the hi def tv at work first. Hope this can help someone else withthe same problem later :)
  • Anonymous Apr 18, 2008
    Same problem, I tried the reset though... Couldn't get it to work, everything else is fine, just in black and white.
When u swith the swith console off  plug it in too the standard def tv but hold the O/1 button for 10 seconds then u will see a nice and shiny ps3 working on ur standard def tv
i had the same problem
Posted on Oct 27, 2007
How do you connect a ps3 to a Emerson 32" TV, with yellow, white, and red cords
your yellow is the video in, white audio left, red audio right.
Feb 25, 2018 | Emerson Televison & Video
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Ok so i bought a play station 3 in iraq while i was deployed it is 220 and i bought a power converter since i got home and it turn on every thing works but it will not put out a signal for my tv neither...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
New tv.. no colour when playing ps3
Hi, check the setting of the TV, where you can see TV display and you will see two or three option of changing the TV mode(NTSC and PAL).it still on NTSC that is while it is sowing black and white. Switch it to PAL it will start showing co lour screen for you to enjoy the game.
Take care.
May 05, 2010 | Sony Playstation 3 (PS3) Console
Black and white display screen
If you have an HDTV use HDMI or component to connect to get colour...if you have an SDTV and use the RGB cables unfortunately the PS3 will output NTSC signals for JApan/NA and your SDTV will accept PAL signals (EU). THere may be an adapter, but if you have an HDTV this problem should solve itself via HDMI/component cables.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
No display on my Ps3
Two or more things, first make sure you have your audio vidio cables correct
Yellow= Video
Red= Audio right
White Audio left
Also make sure that the tv matches the input your cables are connected into. I would make sure the restart the PS3 to make sure the video is good (after checking the tv input)
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Error
If you receive an eight digit 800 series error code, there may be a few solutions.
Update the System Software.
Visit Playstation 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
1. From the XMB home menu, go to (Settings) > (System Settings) > [System Information].
2. The system will display the System Software version number.
Power-Cycle all Network Equipment
Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Please power-cycle ALL of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. After 2 minutes, you can turn on (or plug in) your equipment.
Check Your Enviroment
  • Make sure to allow adequate ventilation to flow from the PLAYSTATION 3's vents (i.e., avoid obstructing the vents with long/shaggy carpet, inadequate airflow from cramped entertainment cabinet setups, etc.).
  • Make sure to keep the PLAYSTATION 3 away from excessive dust, smoke, steam, extreme temperatures, humidity, or direct sunlight.
  • See the PLAYSTATION 3 system Safety and Support manual for full details on Safety Precautions and Use and Handling (manual included with the PLAYSTATION 3 system and available for download from PLAYSTATION 3 Manuals)
Restore Default Settings
During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
  1. From the XMB home menu, go to (Settings) > (System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the (X) button to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup screen before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.
Hope this helps.
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
No video on ps 3
Check your HDMI (looks like USB connetion) Connection or your Composite video connection (yellow, red, white connections.) Make sure they are correct and tight on both your TV and PS3.
Most common connection to use 1st is the Composite video connetions. Yellow is your Video display; Red and White are your Sound!
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
No display after that
Ok shut it off and take the coords out make sure you re-connect the coords back and try it again.. This should fix it! It tooke me 8 times the other day to get a display so i am hoping it works let me know!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3 gone black and white
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
