Question about Bose Wave Radio
Power problem when the player is in a charger i have no problem using it but when i need it for mobile it powers on and off constantly
  • 104 Answers
You will have to replace the rechargable batteries inside the unit , just go to a battery shop they will tell you what sort you need
Posted on May 23, 2009
Need a charger for a Kawasaki power wheels 4 wheeler model: new ninja. What kind do i need for a charger 12 volt for this?
I suggest you refer to the instructions for the specification.
The first requirement is fitting the charger socket and the next is having the correct polarity.
The type of battery is important and the required charge rate/time is also important. A lead/acid battery should ideally use a constant voltage charger. Ni-cads and similar should ideally use a constant current charger.
The vehicle might have it's own intelligent charging circuitry and just need a power supply but if this is not so then the more sophisticated the charger you buy, the longer life the batteries will have.
Apr 29, 2016 | kawasaki Toys
How many volts needed in it? my charger is broken can i use other charger with the same voltage?
Yes buy i will be of same power and the charging point must be same like your old one.
Apr 23, 2015 | Apple Ipod Touch 8gb 2nd Gen Generation 2...
I require a mains charger for Tomtom 4n00.001. I need to charge it from home
You can buy a Tomtom main charger but they are fairly expensive.
You can use a Main powered USB charger along with your normal PC Tomtom USB cable: it should ideally be rated at 1 Amp or more.
You might even have a suitable main USB charger on hand now as they often come with generic MP3/MP4 players and some mobile phones: I use my Huawei U8150 or E585 modem charger for that purpose myself!
Hope it helps.
Sep 23, 2011 | Tomtom ONE GPS Receiver
HpG60 laptop charger port is not functioning properly, I have to wiggle the charger around when its connected to get a charge. I want to fix it because if i want to mobile with the laptop i need to make...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 22, 2011 | HP G60-230US Notebook
My ipod touch just has a constant apple emblem on the screen. it won't let me do anything with it, i can't even see the battery emblem when i try to power it up. and it only turns off sometimes.
Your uipod is not enough power to operate the unit. i think, your ipod cable or ipod charger maybe deffective...used a another ipod cable or charger.
Feb 22, 2011 | Apple iPod touch
I want to switch the power on my car cd player away from the starter, so that i have to turn it on and off myself, rather than when i turn the key. how??
Surely you mean that your cd player is connected to the accessory power and not the starter. If you want your cd player to receive constant power then locate the accessory power wire of the cd player(the one that receives power when the key is on) and connect it to a FUSED constant power source(battery). Usually, if it's a three wire hookup it will be yellow, red and black. Yellow (constant power), red (switched power) and black is ground. If this is the hook up then the red needs constant power. If it's a two wire hook up, red (switched) and black(ground), then the red needs constant power.
Jan 14, 2011 | Car Audio & Video
How do I change the fuse on a hoveround charger?
There are no serviceable parts inside the charger device to my knowledge, the whole charger will need to be replaced. One trick to try first: If the problem is with power, try using your desktop PC power cord to power the charger. If it will fit, plug it in to the charger then into the wall and turn it on and see if you get a light. If so, it was just the power cord, if not, the charger is most likely dead and needs to be replaced- $275.00.
Oct 26, 2010 | Health & Beauty
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Bose Wave Radio Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
