I'm using a Dell 2161DS KVM. One server is a Sun
I'm using a Dell 2161DS KVM. One server is a Sun UltraSparc 60 connected to the KVM with a Raritan Guardian. While working in an xterm, I hit ctrl-ins (ins on the numeric keypad). This seems to be some type of hot-key because it started ''apkmsun/apssun key definition setup'' in the xterm. It looks like a script, but the text it sent to the window was interpreted as commands. I was typing before I noticed I was in a script and remapped my ''r'', ''z'', ''c'' keys. While troubleshooting, I hit the hot hey again and it said I have 3 keys redefined. The instrucions in the text say press a key then use arrows to define the key, but as I said, the ksh xterm doesn't interpret the script well. I hit escape to exit the script. I can't find any manual or docs for this. Since I'm blind to the script in the xterm, I need to find out how to set it back to the default. Thanks for your help.
SOURCE: Hotkeys for D-Link DKVM-2
In my case, it is <Scroll Lock>, <Scroll Lock>, <1> or <2>
And NOT F1 or F2 as the previous writer suggests.
Good Luck,
Ludvik.
Posted on Feb 07, 2008
SOURCE: What are the hot keys to switch between PC's?
You might try Scroll Lock twice followed by Up and Down Aerrows
Scroll Lock + Scroll Lock + Up or #1 or #2... and Scroll Lock + Scroll Lock + Down or #1 or #2 to switch b/w comps
Posted on Jul 28, 2008
SOURCE: KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Posted on Sep 15, 2008
SOURCE: I have a problem while connecting my phone as modem to use internet ?
Please Suggest me how to find modem for this type of laptop computer ( Fujitsu FMV5MTBL3)
Posted on Oct 16, 2008
  • 21 Answers
SOURCE: Toshiba 310CDT / Name the Command Interpreter !!
If you " \ " not work, type type ALT + 0 9 5 on keypad.
095 is ASCII code for " \ "
Posted on Nov 07, 2008
D2CIM-VUSB can use USB 1.0?
They should work, but I would use the PS2 connectors to be sure.
May 15, 2014 | Raritan Computer KVM Extenders...
Raritan SW2USB. Has been working for several years. Today started normally, but suddenly the keyboard was not visible to the switch or either computer. Checked cables, rebooted, etc. Bought a new keyboard...
It sounds like the main switching IC on the board has gone bad...seen it happen before.
Your best bet is to replace it, I would check on Ebay for a good replacement a little cheaper than retail
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 20, 2011 | Raritan CompuSwitch CS2 (CS2-PENT) 2-port...
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
I have a HP eo1010 kvm switch, how do I go about switching from server to server on it?
By default to bring up the On Screen Display press:
CTRL + CTRL
If you flash the firmware to the latest, you can change that key sequence for the OSD to either PrintScrn, CTRL+CTRL or SHIFT + SHIFT.
Jan 08, 2009 | Dell (310-1925) (2R905) KVM Switch
UMT242/USTIP2 not accepting remote clients, local only
I do not know this particular IP KVM but most IP KVM's use SIPPs that must be updated on the KVM when they are attached to the servers. Look for an option in the admin tools that say update SIPPs or update connection. You may also just have to double click on the list of connections to get it to update. This may have to be done at the console and not via remote.
Dec 18, 2008 | Raritan Paragon UMT242 (p2-umt242) 42-port...
Dell kvm switch
I've had that happen when I've added some newer rev SIPs. The newer ones come with a notice to load the 2161DS with versions 2.0.13 or newer firmware; by unplugging the new SIPs and leaving just the older ones (and I'm at a loss as to the exact revisions) I got back the OSCAR prompts. Plug the SIPs back in one at a time, and they would display, but once the session timed out, the key sequence would do nothing once again. Don't know if this is what you have, but I do know that certain SIPs can interact with your firmware to cause this symptom - my bigger problem now, is that when I try to update with the newer firmware (d2_0_13_english.fl) I get a message: "Unable to upgrade the firmware. Reason: Incompatible file."
Dec 11, 2008 | Dell 2161DS KVM over IP Switch (1P500) KVM...
USB mouse not recognized
I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
Feb 18, 2008 | Dell (582RR) 16-port KVM Switch
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
