Question about Sony KV-32FS12 32" TV
Sony KV-32FS12 powers on however the screen is blank, and the red led on the front panel blinks 4
Hi...My Sony KV-32FS12 powers on however the screen is blank, and the red led on the front panel blinks 4 times...Thanks...David
4 Suggested Answers
SOURCE: Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Posted on Jan 28, 2008
priyabrat
  • 123 Answers
SOURCE: Sony KV-32FS12 32" TV
Hi
          It is a problem of high voltage transformer.Better change it.
                             or
High voltage supply is what give the high voltage power, consisting of components. You ask for this or do you mean you need the High Voltage Transformer or another Item on the board? Do not understand!!
                             or
    Test the Switching Transformer
SMPS switching transformers, like flyback
transformers, are high Q transformers.
They are responsible for transferring a
large amount of energy in a short period
of time. A single turn short will shut down
the SMPS. Be sure to use the patented
Sencore ringing test to test any suspect
switching transformer.
                   or
call - 1-800-736-2673(toll free)
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Posted on Mar 28, 2008
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
Sony KV-20Fs100. Same problen as #4620488. TV
4 blink of power led shows problem in vertical deflection section and most probably vertical output IC is defective, replace it to fix the issue.
Regarding .rar file type of service manual files, download winrar software trail version from internet, install it and use it to unzip .rar file to get pdf manual file.
You wont get +B volts because tv switch to protection mode and power supply shuts down. Service manual has blinking standby led error code details as well.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
May 10, 2009 | Sony KV-32FS12 32" TV
Powered on and geting off. No display front led is blinking 4 times.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
Apr 29, 2009 | Televison & Video
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Sony kv-32fq86e 16 blinks
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
Apr 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS12 32" TV Logo
415 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
