Question about Polaris Pb460 Polaris Booster Pump Replacement Impeller
How do i unclog impeller?
How do I unclog my impeller?
  • 110 Answers
Can use water blaster - if no way to take impeller off.
Posted on Jul 07, 2009
How do i repair gec disosal unit
Most Disposals are not worth repairing. If the motor won't work, try pushing the rest button on the bottom of the unit. If it won't turn, use an allen wrench to manually turn the impeller and see if something is stuck. You can also use a broom handle to turn the impeller.
Jan 05, 2015 | Garbage Disposals
How to unclog a shellback laundrytray pump 3 -12-19
1) disconnect power and place towels etc underneath everything
2) break discharge pipe(should be a union fitting for servicing)
3) undo big brass nut under sink basket
4) undo 4 hex head bolts holding pump housing together(sometime can be picked out via inlet and discharge
5) Dont try and take impeller off as the ceramic washer may come off and then you got to get a new one. If motorshaft is rusty, time for a new motor, seal and probably an impeller seal. ceramic impeller seal is epoxied on the impeller
Mar 17, 2014 | Washing Machines
Wont **** properly. is just moving dirt around. i have a G6 i unclogged it changed the bag. dont know what else to do.
With a Kirby that's around 10 years old, there's a good possibilty the fan is worn or broken. You can purchase one online (http://www.elikirbyclub.com/category_93/Kirby-GSix-Fan.htm for $17.55 plus shipping and handling) or at a Kirby store.
Instructions for replacing the impeller can be found at the following site.
http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html
Jan 03, 2011 | Kirby G6 Bagged Upright Vacuum
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Low Hose Suction, Hose is open.
thanks for the clarification.
since the hose in unclogged, the next place to look is in the body of the vacuum.
there is usually a tight turn in the dirt channel in the base. often you can see the clog if you remove the hose.
the next step is to dissasemble the base and look for the clog.
does the motor sound normal?
is the impeller turning at a normal fast rate?.
Jan 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Zoeller M53, pump keeps pumping half the power
try backflushing with high pressure water(carwash) if that doesnt work you have to remove the bottom plate to expose the impeller and remove debri,gasket will probably have to be replaced(silicone) will do
Oct 31, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
The water fills the tank but does not go out of the hose and drain to the sump pump as designed
Check the hose for clog up as well as your sump pump. Have your hose unclogged and let it run. Check the sump pump if this is running. And if it is, and still no water goes out. Open the sump, and check the impeller for defect. Impeller is the one that turns around to push the water out. If it is defective, you must replace it to make it run.
Once you are done, power it up and start it.
Sep 27, 2009 | Haier HDN655E Dehumidifier
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
HE2 Draining problem
If its no draining at all. Open the pump back up and there should be a small hole about the diameter of a quarter to the left. Inside you should feel the impeller with your finger. Try to spin the impeller with your finger, it should have some resistance and a recoil as it turns. If not, than the impeller shaft is broken and the pump needs replacing. Hope tht helps, Dave www.washermd.com
Dec 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Polaris Pb460 Polaris Booster Pump Replacement Impeller Logo
275 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
