Canon EOS 400D Digital Camera Logo
Posted on May 16, 2009
Error99 sir i have canon 400d i work witin 3 year 1st time there was problam in cilk in pictur the camra disply error 99 many time we change the battary & turn offf the camera but problam was still pls tell me how can solve this problam
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 08, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
216
Points
Anonymous
Level 1:
  • Contributor 53 Answers
  • Posted on Aug 27, 2009
Anonymous
Contributor
Level 1:
Answers
53
Questions
0
Helped
15021
Points
87
Err 99 is moisture or dew inside the camera.
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
I have a canon eos450 that showsan error99 when on automatic. It seems to be related to the flash being released when going to use the camera. I is fine on the other functionsPV AV etc but not where the...
Error 99 is a generic error code and only Canon can diagnose it. But given that it occurs when the flash is set on, it must mean there is a fault with the flash circuit. You may need a technician to replace or repair the circuit. Alternatively, you could purchase an external flash if the first option turns out expensive.
2answers
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
My Canon is displaying - Err 99 what should I do?
See if Sigma has any updated advice on this. Otherwise, I don't mean to sound rude or harsh, but unfortunately you may be out of luck with the compatibility...you will need to get a Canon lens. Error 99 is just a communication error and cleaning the contacts is about all you can really do so if that hasn't worked...I'm sure this is not the news you want to hear, but contact Sigma if you haven't already and see what they say.
Take care!
2answers
Error 99
i had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
3answers
Canon 400D
Use a card writer and copy your pictures to the CF card on the computer.
40helpful
17answers
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
