Question about Canon PowerShot SD1000 Digital Camera
There is no picture the screen is black
When i turn on the camera the picture doesn't come up. the screen is just black.
    President:
  • 1,223 Answers
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 19, 2009
Viewing Screen Doesn't Work
Your camera suffers from internal fault that you will not be able to test. needs to go to shop or a cheaper way will be to replace it with one that is working. No JOKE, very costly to repair.
Oct 08, 2012 | Kodak EasyShare Z740 Digital Camera
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
When i open my camera to take a picture all i get is a black view. i cannot see anything on the display or through the view finder.
Does your camera also have an optical viewfinder? If so, chances are that you accidentally pressed the button that turns the screen off to save battery power. You would then use the optical viewfinder in its place. For your model camera, read the user manual to find out where this button is. On Canon cameras, it's usually a little button labeled DISP or DISPLAY. Just press it oonce to turn the screen back on again.
But if the above doesn't help, have you tried downloading photos taken when the screen is black? Are these photos also black? If so, chances are in this case that you are experiencing a stuck shutter. This is also very easy to remedy (see this).
Sep 05, 2011 | Cameras
When I turn on my camera, it shows a black screen, so I'll take a picture anyways and its black.. no picture ..is it fixable or should I throw it away? Next to where the flash goes off..there is a...
Is the lens protector opening in the front of the lens???
If it is and things are still black then throw it out... it will cost more then it is worth to fix...
Lens Errorfix for Digital Camera
heatman101
May 26, 2011 | Fuji FinePix F460 Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
