Question about Power Acoustik A2400DB Car Audio Amplifier
4 AWG amp wire
I have hooked up everything and the system works great. 2 PA 12's and a 2400W PA amp with a 2 farad cap. everything works great but the 4 awg wire is hot in the engine compartment. from the batter to the fuse and then a little on past the fuse. The jeep was left overnight and when looked at this morning... the wire was still hot after the engine compartment was cool. Any Suggestions?
    Scholar:
  • 105 Answers
For that amplifier you need to be running 0 gauge wire . Also check your ground to make sure you have the best connection possible.
Posted on May 18, 2009
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
The xxx 3.0 farad capacitor does not seem to have a remote wire terminal...was wondering how to find and hook up the remote wire.
Caps don't need remote wire. Remote wire goes directly from the deck to the amp, as it turns the amp on. Capacitors main function is to store the power from the battery and pass it on to the amp, thus not needing a wire to turn it on.
Feb 20, 2011 | xXx Audio 3.0 Farad Digital Capacitor Dont...
I have a 1200 watt amp and 2 12 in pioneer champions and it keeps killing my battery how do I hook up this capasitor I just bought?
first make sure your power wire is directly hooked to the battery, {make sure ure in line fuse is pulled} power wire that goes to positive of power cap , ground wire is grounded to chasis, now attach aditional power wire to amp and aditonal grond to amp . make sure all conections are solid and tight { also make sure inside of power cap is tight as well after long periods of time the insides loosen } i have 2 -1,000 watt sony xploid amps and 2- 1,200 watt sony expoid subs and they pound hard . i probley should have 2-1.2 farrid caps for what i have but it seems that its holding its own
Dec 04, 2010 | Metra Tsunami 1.2 Farad Capacitor
Amp draw, voltage dropping from 14.6 to under 12v
I would not use a bigger cap, I would use a bat cap. If u dont know about these look them up they work wonders
Feb 19, 2010 | Hifonics BXi1608D Car Amp
Lights dim when bass hits....
you need to upgrade your electrical system.
First easy thing you can do is buy a bigger battery. Get a battery with the highest cold cranking amps(cca) that will fit. Yellow top would be great.
If you have the $$ have a higher amp alternator put in. these are very expensive.
this is an advanced solution, and any vehicle with a big amp should have this done. Its called a big 3 upgrade.
Get some at least 2 awg hook up wire. you will need enough to run a wire to the neg of the battery to the chassis to your altinator. and enough to run from the pos on the bat to the pos on the altinator. and from the neg to the frame of the car.
Use copper lugs and solder them on the ends of the wires. Use a blow torch and pliers to hold it and heat it up. Melt solder into it about half way full, and then push stripped end into it, then squelch it with a damp cloth and wipe it off.
Do this for all, and hook everything up.
You can install a CAP if you want. I personally don't believe in them. They help the car dimming a little, but the lower the voltage at the amp.
Dec 15, 2009 | Jl Audio 500/1 Car Audio Amplifier
Car subwoofer problems
The cable should not cause the problem unless it is shorting out somewhere on the remote or positive cable. I would use a larger gauge wire first as this is the cheaper way to go, and if the same problem occurs you are having a short in the sub or box causing the protection mode. You will have to back trace to find possible cross connections.
Jun 21, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I bought a 2400 watt punch 801s amp that has two power out and two ground outs i've hooked up only one power and one ground and the amp comes on but as soon as i touch the speacker wire to it it hits one...
Check the gauge on the wiring. For that size amp you would need to use 0 AWG wire for the power, the speaker wire is just signal wire so you want to use regular speaker wire. (I have 12 AWG setup for speaker wires) What the two power ports (Neg and Pos) do is increase the amount of flow. Two power wires to distribute the flow of the current so you don't burn up your wires if your pumping too much juice. I started off with this exact amp running a single 8 AWG and split it into two and it burned up and blew a fuse after a couple of huge bass hits. So proper setup would be....
BAT(+)---FUSE HOLDER(60AMP+)---DISTRIBUTION BOX(30AMP+)====AMP
GND(-)===AMP
-- would be 1 wire pref 0 AWG splitting into more 0-4 AWG
== would be the 2 wires (Yes two ground points in separate locations would be better)
Thus finalizing you have a proper setup.
Be careful you don't burn out your alternator, this bad boy can cause some serious problems with a lower amp alternator. Let me know how it works out.
Aug 15, 2008 | Rockford Fosgate Car Audio & Video
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
2.0 Farad Capacitor
The answer is yes, any amount of amplifiers can be hooked up to a cap. Obviously the more amps you hook up to it the less you are going to nodice the difference with the same amout of farads. The only thing that I am worried about is the wiring from your battery to your cap. As long as you have a decent gauge wire running back you should have no problem. And for this instance I would recommend 0 guage, you might be able to get away with 4 but I would highly recommend 0. Over all I would recommend 0 guage on all installs unless you are going small and don't plan on upgrading. I hope I could help
-Andrew Hawkins
Apr 23, 2008 | Car Audio & Video
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
May 30, 2007 | Sony XM-2002GTR Car Audio Amplifier
Power Acoustik A2400DB Car Audio Amplifier Logo
98 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
