Question about Whirlpool LER5636P Electric Dryer
HAVE A 8 YEAR DRYER( Kitchen Aid)
The building recept. burnt out completly one power leg without breaking a breaker at the electric box. our dryer plug showed slight yellow melt area while the same leg in wall was dark hole (BURNT) . After the recpt. was changed the dryer was plug back in for less than a minute no air low heat medium heat than high heat all worked plus motor. than unpluged and found out that our plug was dark colored burnt same powe leg. Could the dryer still be good if we had put a new cord on our dryer? and by the way we never use the high heat setting
  • ffarnum May 16, 2009
    I won't know yet , but at a later time. we are on ss income and both both are 78 my felklings is the dryer is good but this buildings age & the recept. too and when it burnt out i should have put on a new dryer cord, mabe not I don't like a electrical problem go on with out knowing why
    MY WIFE WANTS US TO GET NEW ONE, WE HAVE BRAND SOURCE CREDIT SO I THINK WE'LL DO THAT BUT I STILL WILL BE WONDERING, I DON'T HAVE THE TOOLS THAT I HAD SO I HAVE TO DEPENDEND ON OTHER PEOPLE, GOD BLESS YOU FOR RESPONDING
    FRED, sr.
  • 323 Answers
I would be checking the service panel. I'm assuming the dryer has been working in that outlet. If the breaker is over 50 amps that is why it didn't trip. But the breaker may be bad itself. Make sure it is wired properly. Red wire should go on one side of the breaker and the black on the other. The white should go over to the neutral bar. Then make sure the outlet you plug into is wired the same way. (MAKE CERTAIN THAT BREAKER IS OFF) The top two prongs should have a red on one side and a black on the other, with the white at the bottom. If these are correctly wired, the problem is either in the breaker or inside the dryer. Depending upon the model you have, a 50 amp double breaker isn't prohibitively priced. If you buy the breaker, wire it the same, turn it on, plug in the dryer and it happens again, the dryer is at fault. Coils burn out inside them, lugs burn through, but I'd feel more comfortable at that point calling a service man, tell him what you've done with wiring, breaker, and outlets. It may be time for a new dryer.
Sirwriter
Posted on May 16, 2009
  • Dan Todd May 16, 2009
    Thank you Fred, but you really need to have a look at that breaker and outlet. Maybe you have a relative you can direct through what I outlined. I would just be leary of plugging in a new dryer in the proble were in the outlet ot breaker box. Things happen. A wire could have come loose. Wish you lived by me!
    Sirwriter
My dryer, Kitchen Aid KEYS850LQ does not cool down! The buzzer goes off, I open the door to remove clothes, and they are so hot I can hardly touch them!!! The dryer is only 6 years old - it never has...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | KitchenAid KEYS850LQ Electric Dryer
LG electric dryer is not heating. Electric coils test for continuity. Any suggestions?
There are several things that can prevent a dryer from not heating. UNPLUG DRYER BEFORE TESTING ANYTHING.
1- power- Test the receptical to make sure you are getting 220 volts. To do this you need and voltage tester. Both legs should pull 110 and together 220. If one leg is not pulling any power than your breaker is half tripped. Reset breaker to cure your problem. If problem persist it is in the breaker or receptical.
2- cord- To test this unplug dryer. Take the panel covering the cord connections off. Remove cord entirely from dryer. Test each leg for continuity. If any are not showing cont than replace cord.
3- Themal fuse- To test this remove access back access panel on some front panel. By the blower housing there is a fuse white thin sliver or round fuse with 2 wires going to it. The one with 4 wires is your low limit cycling thermistat. The thermal fuse is near that. Disconnect the 2 wires and check fuse for continuity. If meter shows cont fuse it good. If not replace fuse.
4- Hi Limit Thermistat- test same way as thermal fuse. On the heating element housing at the bottom are 3 wires running to a fuse. Test the left and right. The bottom is attached to one of the sides.
5- Thermal Cutoff- Test same way as thermal fuse. This fuse is near the top of the heating elemnt above the Hi Limit. 2 wires with usually plastic covers on them.
6- Heating Element- Below high limit 2 wires. Test for continuity.
If all these fuses are good than you may need to call a technician. The motor may not be getting to the right rpm to activate the senfrigrial switch in the moter. Timer or control board may be out.
7- Motor- If
Jul 16, 2011 | LG DLE2514 Electric Dryer
Dryer wont turn on. Breaker in breaker box is fine. No light inside dryer. What's wrong?
Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer not turning on
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Estate TEDX640JQ Electric Dryer
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
My dryer just won't start when I press the start
The electrical breaker may not be turned on. Check the homes main electrical breaker panel and ensure the breaker marked Dryer is in the on position. If this does not work, you may need to call someone in to take a look at the dryer.
Jan 25, 2010 | KitchenAid Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
