Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Food particles clogging up drainage system at bottom of dishwashe
How do I clean it without taking apart the dishwasher?
    President:
  • 3,113 Answers
Take it apart. Clean large particles of food off before placing in unit. You might try a little Clorox and wash at hottest temperature while empty first.
Posted on May 16, 2009
Poor rinse on maytag model mdb8600awq
Did you check the screen at the bottom of your dishwasher? It may be clogged with food particles. If these particles aren't small enough to get flushed down they will just recycle through the water.
I always make it a practice to rinse off my dishes before I place them in the DW. Some newer models have better drainage systems, but perhaps yours is an older model.
Dec 22, 2012 | Maytag Dishwashers
Not Rinsing
By cleaning it out, you cleaned the bottom where the water is drawn in and food particles collect, right? Are the sprayer arms working good? The holes on them are not clogged with anything? How does the dishwasher drain? I mean do you have an air gap or does it drain directly into the disposal or sink pipe. Sometimes without an air gap, the disposal will send junk into the drain line if the check valve is not working properly, thus giving you excess food in the dishwasher.
Jan 12, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
May 02, 2011 | LG Dishwashers
Water standing in bottom after cycle complete
Either your drain filter is clogged, or you're having drainage problems in the line. My first step would be to take apart the bottom of the dishwasher according to the manual and making sure there isn't any food stuck in the bottom drain. I had to do this about a month ago to get some spaghetti out, it's not very difficult, just be careful not to drop any screws.
Feb 28, 2011 | LG Dishwashers
Filter needs cleaning. How do I get at the filter?
Dishwasher filters are important to catch food particles and other debris. The dishwasher cleans small portions of food from the dishes, cooking pans and silverware. These particles must go somewhere. The drainage system on the washer may clog if filters are not present. Most Maytag dishwasher models have two types of filters, "Coarse" and "Fine." You should clean the "Coarse" filter after two or three wash loads. The "Fine" filter can wait for a cleaning for about 300 loads or three months.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Sink sponge
  1. Empty the dishwasher. Remove all dishes including pots, pans and silverware.
  2. Pull the bottom rack out as far as possible. The filters are under the basket on the Maytag dishwashers. It may be convenient to lift the rack out. Typically, if you lift, the wheels leave the track.
  3. Remove the "Coarse" filter. This filter is a small, round knob in the middle of the "Fine" filter. A round knob is around the "Coarse" filter. Hold on to the handle and lift straight up.
  4. Knock the contents of the "Coarse" filter into the garbage can. Run the faucet to remove smaller particles. Wipe the dishwasher filter with the sink sponge if debris is stuck-on. Push back into the filter holder when complete.
  5. Take out the "Fine" filter. Turn the round knob that is around the "Coarse" filter counter-clockwise. Once the knob is loose, pull up. The "Fine" filter will come out of the dishwasher.
  6. Rinse the "Fine" filter with the hot water faucet. Scrub with the sink sponge to remove any stuck-on fragments. Replace the filter into the dishwasher. Push down and turn the knob clockwise to tighten.
Jan 09, 2011 | Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Food particles left on dishes. Whirlpool quiet partner 1
You do not have to take it apart to clean it. You can run it a couple of times with dishwasher tablet and it will self clean. In general I recommend rinsing the food off of the dishes and silverware before placing items into the dishwasher. Also, run the hot water in the sink until it gets hot and then turn on the dishwasher. good luck with it.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Dec 22, 2008 | Maytag Dishwashers
Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
Nov 30, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
236 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
